get_int()?!!
hadeelqasaimeh
get_int()?!!
PostPosted: Mon May 14, 2007 1:37 am     Reply with quote
hi
i have two codes,first to work as TX and seconde to work as RX
as below:
#include <16f877a.h>
#fuses hs,NOWDT,NOLVP
#use delay(clock=20000000)    //one instruction=1us
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
int value;
void main()   {
    set_tris_d(0xff);
   value = input_d();
   delay_ms(5000);
   printf("%u",value);
   }//while
}//MAIN
rx:
#include <stdlib.h>
#include <INPUT.C>
signed int value,i;
char RX[3];
int1 flag;
#INT_RDA
void serial_isr() {
  value= get_int();
  output_d(value);
  flag=1;
void main()   {
    flag=0;
    set_tris_d(0x00);
    enable_interrupts(INT_RDA);
    output_d(0x00);
   if (flag==1)
   //output_d(value);
   //delay_ms(1000);
   flag=0;
   }//while
}//MAIN
first work fine
second cant convert ascii to hex
i try with atoi()
and try with get_int()
and try with:
unsigned int Ascii2Int()
//convert an ascii string to an interger
   return((rxBuffer[0]&0x0f)*100+(rxBuffer[1]&0x0f)*10+(rxBuffer[2]&0x0f));
but no way!!! it out nothing
help me please
PostPosted: Mon May 14, 2007 2:28 am     Reply with quote
get_int() doesn't work because this internally function calls get_string() which in turn waits for the string to be terminated by a carriage return character (0x0D).
You can fix this by changing the transmitter to send a CR as well.
printf("%u\n",value);
Similar reason for atoi() to fail. atoi() expects a zero terminated string as input.
hadeelqasaimeh
PostPosted: Mon May 14, 2007 2:53 am     Reply with quote
thank you
its work fine
