Conversion 80C51 family for PIC16F877
w_arm
PostPosted: Thu May 10, 2007 10:47 am     Reply with quote
Which are the necessary modifications below for the code to work with PIC16F877??
//Project: SHT11 demo program (V2.0)
//Filename: SHT11.c
//Prozessor: 80C51 family
//Compiler: Keil Version 6.14
//Autor: MST
//Copyrigth: (c) Sensirion AG
#include "AT89s53.h" //Microcontroller specific library, e.g. port definitions
#include "intrins.h" //Keil library (is used for _nop()_ operation)
#include "math.h" //Keil library
#include "stdio.h" //Keil library
typedef union
unsigned int i;
float f;
}value;
// modul-var
enum {TEMP,HUMI};
#define DATA P1_1
#define SCK P1_0
#define noACK 0
#define ACK 1
//adr command r/w
#define STATUS_REG_W 0x06 //000 0011 0
#define STATUS_REG_R 0x07 //000 0011 1
#define MEASURE_TEMP 0x03 //000 0001 1
#define MEASURE_HUMI 0x05 //000 0010 1
#define RESET 0x1e //000 1111 0
// writes a byte on the Sensibus and checks the acknowledge
char s_write_byte(unsigned char value)
unsigned char i,error=0;
for(i=0x80; i>0; i/=2) //shift bit for masking
if(i & value)
DATA=1; //masking value with i , write to SENSI-BUS
DATA=0;
SCK=1; //clk for SENSI-BUS
_nop_();_nop_();_nop_(); //pulswith approx. 5 us
SCK=0;
DATA=1; //release DATA-line
SCK=1; //clk #9 for ack
error=DATA; //check ack (DATA will be pulled down by SHT11)
SCK=0;
return error; //error=1 in case of no acknowledge
// reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
char s_read_byte(unsigned char ack)
unsigned char i,val=0;
if(DATA)
val=(val | i); //read bit
SCK=0;
DATA = !ack; //in case of "ack==1" pull down DATA-Line
SCK=0;
return val;
// generates a transmission start
void s_transstart(void)
// _____ ________
// DATA: |_______|
// ___ ___
// SCK : ___| |___| |______
DATA=1;
SCK=0; //Initial state
_nop_();
SCK=1;
_nop_();
DATA=0;
_nop_();
SCK=0;
SCK=1;
_nop_();
DATA=1;
_nop_();
SCK=0;
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
void s_connectionreset(void)
// _____________________________________________________ ________
// DATA: |_______|
// _ _ _ _ _ _ _ _ _ ___ ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
unsigned char i;
DATA=1;
for(i=0; i<9>=1 in case of no response form the sensor
// makes a measurement (humidity/temperature) with checksum
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
unsigned error=0;
unsigned int i;
s_transstart(); //transmission start
switch(mode)
{ //send command to sensor
case TEMP : error+=s_write_byte(MEASURE_TEMP); break;
case HUMI : error+=s_write_byte(MEASURE_HUMI); break;
default : break;
for(i=0;i<65535>100)
rh_true=100; //cut if the value is outside of
if(rh_true<0.1)
rh_true=0.1; //the physical possible range
*p_temperature = t_C; //return temperature [C]
*p_humidity = rh_true; //return humidity[%RH]
// calculates dew point
// input: humidity [%RH], temperature [C]
// output: dew point [C]
float calc_dewpoint(float h,float t)
float k,dew_point ;
k = (log10(h)-2)/0.4343 + (17.62*t)/(243.12+t);
dew_point = 243.12*k/(17.62-k);
return dew_point;
// sample program that shows how to use SHT11 functions
// 1. connection reset
// 2. measure humidity [ticks](12 bit) and temperature [ticks](14 bit)
// 3. calculate humidity [%RH] and temperature [C]
// 4. calculate dew point [C]
// 5. print temperature, humidity, dew point
value humi_val,temp_val;
float dew_point;
unsigned char error,checksum;
unsigned int i;
s_connectionreset();
error=0;
error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI); //measure humidity
error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP); //measure temperature
if(error!= 0)
s_connectionreset(); //in case of an error: connection reset
humi_val.f = (float)humi_val.i; //converts integer to float
temp_val.f = (float)temp_val.i; //converts integer to float
calc_sth11(&humi_val.f,&temp_val.f); //calculate humidity, temperature
dew_point = calc_dewpoint(humi_val.f,temp_val.f); //calculate dew point
//send final data to serial interface (UART)
printf("temp:%5.1fC humi:%5.1f%% dew point:%5.1fC\n",temp_val.f,humi_val.f,dew_point);
//----------wait approx. 0.8s to avoid heating up SHTxx------------------------------
for(i=0; i<40000; i++); //(be sure that the compiler doesn’t eliminate this line!)
PostPosted: Thu May 10, 2007 11:48 am     Reply with quote
Look at these threads. They have information about converting code
from another compiler to CCS.
http://www.ccsinfo.com/forum/viewtopic.php?t=29114
http://www.ccsinfo.com/forum/viewtopic.php?t=18932
http://www.ccsinfo.com/forum/viewtopic.php?t=22804
http://www.ccsinfo.com/forum/viewtopic.php?t=24869
http://www.ccsinfo.com/forum/viewtopic.php?t=22224
Also, don't expect other people to do the code conversion for you.
A lot of students are coming on here lately and expecting to get
one free hour of engineering time, in converting some code they
found on the web to CCS. This is too much to ask for.
