Hey pals..i'm little new to PIC C Codin.. i got a silly doubt.. pls clarify..
When we code in assembly to make the program run continuously we give a CALL/JUMP to START at the end of the code ... but when we code in C using CCS compiler is it necessary to loop it or does the compiler loops itself automatically?? I've to run a code continuously on PIC.. Pls clarify this...
Neutone
Re: Continuously running C Code on PIC
Posted: Thu May 10, 2007 9:57 pm
Within main place a while(true) to run all code to be repeated.
