need help pls for manhester encoding
sacalu
PostPosted: Thu May 10, 2007 5:35 am     Reply with quote
hey,this might be a stupid request but since i'm a newbie at this i'll do i anyway Smile .i want to encode manchester a character send via rs232....so here's my code
#include   "E:\PICC\Devices\16f88.h"
#use DELAY(clock=8000000,internal)
#use rs232(baud=9600, xmit=pin_b5,rcv=PIN_B2)
#use fixed_io(a_outputs=pin_a0)
#fuses intrc,mclr,noprotect,nowdt,nowrt,nolvp,noput,nocpd
int i,b=0;
char a,c,e1,e2;
int16 f,e=0x0000;
c=getch();
a=c;
for (i=0;i<7>>=2;
    if (c&&0x01)
   {e=e^0x8000;}
   {e=e^0x4000;}
   c>>=1;
putchar(a);
f=e;
e1=f;
f>>=8;
e2=f;
/*while (b==0){
for (i=1;i<=7;i++)
    if (e2&&0x01)
    output_bit(pin_a0,1);
    else output_bit(pin_a0,0);}
    delay_ms(30);
for (i=1;i<=7;i++)
    if (e2&&0x01)
for (i=1;i<=7;i++)
     if (e1&&0x01)
the questin is this code send's the 16 bit variable wright...if not can u suggest some way to do this
PostPosted: Thu May 10, 2007 6:13 am     Reply with quote
We can't read your code as the forum interpreted some of the source code as HTML text. When posting code please tick the 'Disable HTML in this post' checkbox, also use the 'code' buttons in order to preserve the formatting.
Registering to this forum is free and gives the advantage that you can edit an earlier post. Also you can then set the 'Disable HTML in this post' as a default setting in your profile.
From the part of your code that is readable
 if (e2&&0x01)
Here you should use the 'bit wise' AND operator, now you are using the 'logical' AND (use & i.s.o. &&).
Use the search function of this forum, Manchester encoding has been discussed several times in the past.
