int declaration is 8 bits, any way to make it 16 bits???
leeccs
PostPosted: Wed May 09, 2007 6:18 am     Reply with quote
This might be a newbie question.
When I define an int variable, the compiler always makes it 8 bits instead of the normal 16 bits. Is there any way to make the compiler define int as a standard 16 bit integer, or do I always have to declare variables as int16 ??? This is a pain when converting existing programs.
PostPosted: Wed May 09, 2007 6:28 am     Reply with quote
Yes, changing is possible. Check the #type directive in the CCS manual.
jds-pic
Re: int declaration is 8 bits, any way to make it 16 bits???
PostPosted: Wed May 09, 2007 1:32 pm     Reply with quote
on a PIC, "normal" is 8 bits -- it is, after all, an 8 bit microcontroller. so, it is incorrect to assert that the compiler is doing something to make an int 8 bits wide, instead of 16. 8 bits wide is the natural state, 16 bits wide and greater requires work -- not the other way around.
personally, i would never change the global int definition from 8 to 16bits.
number 1, you are asking for trouble, and will eventually run into some hard to find problem either in your own application code, your imported application code, the compiler libraries, or a device driver.
number 2, you are unnecessarily doubling the RAM usage.
number 3, almost everything you do on a PIC in terms of I/O is done with 8 bit values -- serial rs232, i2c, dallas onewire, SPI, and so on. you are going to cause yourself much grief when needlessly using 16 bit values.
my suggestion -- open your imported code in a suitable text editor, and use stepwise search and replace -- selectively changing the int's into int16's. then, pull that into your application codebase.
jds-pic
PostPosted: Wed May 09, 2007 2:49 pm     Reply with quote
I fully agree with JDS-PIC in his reply.
However, to be fair and answer your question:
Yes, you can change the default. In the latest manual, see pages 23 (Basic and Special Types) and the #Type pre-processor command on page 103.
Neutone
PostPosted: Wed May 09, 2007 4:00 pm     Reply with quote
Remember that integer literally means its not a floating point number. I would say it falls under best practices to declare every variable used with embedded code explicitly. On a PC it's a lot looser.
Int1
Int8
Int16
Int32
