string Hex into int
string Hex into int
PostPosted: Wed Nov 16, 2005 6:08 am     Reply with quote
I'm trying to translate the following ASCII string: "RD 2B0 A3 58"
into: RD, 0x2b0, 0xA3, 0x58
What is the simples why to do it ?
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Wed Nov 16, 2005 7:39 am     Reply with quote
I would write something like this:
#define NUMBER_OF_VALUES 4
int i, k, value;
int16 values[NUMBER_OF_VALUES] = {0,0,0,0};
k = 0;
for (i = 0; i < length(ASCIIstring); i++)
   if (i == ' ')
      k++;
      value = 0;
      if (k == NUMBER_OF_VALUES)
         i = 255;//to avoid array-overflow
      value = ASCIIstring[i] - '0';
      if (value > 9)
         value = (value + '0') - 'A';
      values[k] = (values[k] * 16) + value;
this code might contain syntax errors and so you should check it first.
Off course, there are more ways to do it, and this is probably not the best...
PostPosted: Thu Nov 17, 2005 2:01 am     Reply with quote
Thanks,
This example was waht I'm looking for ..
