Any algorithms to multiplex ccp to generate 4 square waves?
Posted: Sun May 06, 2007 9:08 am
hello everybody,
I am timing 2 square waves with a fast timer2 interrupt, but adding more outputs will slow the code a lot.
I am wondering about how to generate 4 similar waves (duty cycle can change) and sync them with a main wave. This sync can be out of phase from 0 to 90 degrees. The hardest part would be this syncing I think.
Previous researches resulted to linked lists and binary trees but I could not see how to make it work.
So I ask how would you solve it?
Thank you.
jma_1
Posted: Mon May 07, 2007 6:49 am
Greetings,
Perhaps a PLL is the way to go. Here is a chip offered by National Semi that might put you in the right direction (2 channel?).
Posted: Mon May 07, 2007 7:18 am
Try googling "numerically controlled oscillator". That is a powerful technique but a PIC can only do it at audio frequencies. I have a PIC16C54 generating up to 32kHz. _________________ The search for better is endless. Instead simply find very good and get the job done.
future
Posted: Mon May 07, 2007 9:55 am
Yes I need it for 350hz maximum with a resolution of 1/4hz.
