I2C slave locking Clock low?
nmeyer
PostPosted: Mon May 07, 2007 9:24 am     Reply with quote
I have been testing a program for my device with an commerically purchased I2C reader/writer. I find that my code works well with the reader as long as i set the Maseter device to read 1 byte. (this is a user changable varible in the PC software for the reader). If i try to change it to have the master read 2 or more bytes, my PIC will hold the clock line low and will not release until i do a reset of the PIC. Does anyone have ideas what might be the issue?
Compiler 4.027
#include <16F819.h>
#device adc=10
#use delay(clock=4000000, RESTART_WDT)
#fuses WDT,INTRC_IO, PUT, MCLR, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG, NOPROTECT
#use i2c(MASTER,slow,sda=PIN_B2,scl=PIN_B5)
//#use i2c(SLAVE,Fast,sda=PIN_B1,scl=PIN_B4,address=0x16)
#include <math.h>
#use fast_io(A)
#define LED1 PIN_A0 //100% led
#define LED2 PIN_A1 //80% led
#define LED3 PIN_A2 //60% led
#define LED4 PIN_A3 //40% led
#define LED5 PIN_A4 //10-20% led, yellow
#define LED6 PIN_A6 //below 10% or fault led, red
#use fast_io(B)
#define sw_in PIN_B0 //switch
#define SMBD_E PIN_B1 //smbus data external
#define SMBD_I PIN_B2 //smbus data internal
#define SMBC_E PIN_B4 //smbus clock external
#define SMBC_I PIN_B5 //smbus clock internal
#define INTS_PER_SECOND 15
int address;
char i,loop,int_count,bus_free,fault,change_current,chg_term=0,set=0;
int lsb_current,msb_current,count=0,lsb,msb;
long time1,seconds,voltage,percent,status,temperature,capacity,ch_current;
long time_cnt=0,value;
int32 new_val;
signed long current;
signed int i2c_temp;
#int_rtcc
clock_isr()
if(--int_count==0) //decrement counter until 0
++seconds; //count up seconds
int_count=INTS_PER_SECOND; //reset counter
if (seconds>=65000)
seconds=65000;
void read_sm_percent (void)
i2c_start(); //read capacity
i2c_write(0x16);
i2c_write(0x0E); //absolute state of charge
i2c_start();
i2c_write(0x17); //tell battery to write data
percent=i2c_read(0); //read the data
i2c_stop();
output_float(SMBC_I); //release data line
output_float(SMBD_I); //release clock line
void read_sm_temperature (void)
i2c_start(); //read temperature
i2c_write(0x16); //battery address
i2c_write(0x08); //temperature register
i2c_start();
lsb=i2c_read(); //read in data bytes
msb=i2c_read(0);
i2c_stop();
temperature=make16(msb,lsb); //make word
temperature=temperature-2740; //change to celcius
i2c_temp=temperature/10; //make degrees 1C
void read_sm_voltage (void)
i2c_write(0x09); //voltage register
i2c_start();
lsb=i2c_read(); //read data bytes
msb=i2c_read(0);
i2c_stop();
voltage=make16(msb,lsb); //make word
voltage=voltage/100;
void read_sm_current (void)
i2c_write(0x0A); //current register
i2c_start();
lsb=i2c_read(); //read bytes
msb=i2c_read(0);
i2c_stop();
current=make16(msb,lsb); //combine into a word
void read_sm_capacity (void)
i2c_write(0x0F); //current register
i2c_start();
msb=i2c_read(0);
i2c_stop();
capacity=make16(msb,lsb); //combine into a word
capacity=capacity/64;
void read_sm_charging_current (void)
i2c_start(); //read status
i2c_write(0x14); //current register
i2c_start();
msb=i2c_read(0);
i2c_stop();
ch_current=make16(msb,lsb); //combine into a word
ch_current=ch_current/64;
void read_sm_status (void)
i2c_write(0x2F); //status register
i2c_start();
lsb=i2c_read();
msb=i2c_read(0);
i2c_stop();
status=make16(msb,lsb);
#int_ext
rb0_isr()
#use i2c(Master,slow,sda=PIN_B2,scl=PIN_B5) //change to internal smbus
delay_ms(20);
while (!input(sw_in)) //watch switch depression
if ((temperature>=400) || (temperature<=50) || (voltage<=180))
fault=1; //look for fault condition
fault=0;
if (fault==1) //fault is there
output_low(LED5); //flash led
output_high(LED5);
if (fault==0) //if no fault, show capacity
if (percent<=129 && percent>=80) //in different LED percentages
output_low(LED1);
output_high(LED1);
if (percent>=60)
output_low(LED2);
output_high(LED2);
if (percent>=40)
output_low(LED3);
output_high(LED3);
if (percent>=20)
output_low(LED4);
output_high(LED4);
if (percent<=19 && percent>=10)
output_low(LED5);
output_high(LED5);
if (percent<=9 && percent>=0)
output_low(LED6);
output_high(LED6);
fault=0;
output_high(LED1); //turn led off
output_high(LED2); //turn led off
output_high(LED3); //turn led off
output_high(LED4); //turn led off
output_high(LED5); //turn led off
output_high(LED6); //turn led off
output_float(SMBC_E); //release data line
output_float(SMBD_E); //release clock line
#use i2c(SLAVE,fast,sda=PIN_B1,scl=PIN_B4,address=0x12,RESTART_WDT)
//change back to external smbus
#INT_SSP
void ssp_interupt (void) //detect external smbus activity
BYTE incoming, state;
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
//incoming = i2c_read(1);
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
msb_current = incoming;
change_current=1;
/* if(state == 3) //third received byte is data
lsb_current = incoming;
//change_current=1;
if(state == 0x80) //Master is requesting data
i2c_write(lsb); //write first byte
// if(state > 0x80)
//i2c_write(msb); //write second byte
output_float(SMBC_E); //let go of clock line
output_float(SMBD_E); //let go of data line
void write_sm_current (void)
i2c_start();
i2c_write(0x16);
i2c_write(0x00);
i2c_write(0x06);
i2c_write(0x06);
i2c_stop();
i2c_start();
i2c_write(0xA0);
i2c_write(0x1A);
i2c_write(msb_current);
i2c_write(lsb_current);
i2c_stop();
delay_ms(20);
i2c_start();
i2c_write(0x16);
i2c_write(0x7D);
i2c_write(0x80);
i2c_write(0x00);
i2c_stop();
i2c_start();
i2c_write(0x16);
i2c_write(0x7D);
i2c_write(0x00);
i2c_write(0x00);
i2c_stop();
void sm_free (void)
while (count<=16)
if (input(SMBC_I))
bus_free=1;
bus_free=0;
count=17;
delay_us(3);
count=count+1;
count=0;
setup_oscillator(osc_4mhz);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_8);
setup_counters(RTCC_INTERNAL,RTCC_DIV_256);
set_rtcc(0);
enable_interrupts(INT_RTCC);
ext_int_edge(0,H_TO_L);
enable_interrupts(INT_EXT);
enable_interrupts(INT_SSP);
setup_timer_1(T1_DISABLED);
port_b_pullups(false); //added to see if this could be used on chg
set_tris_a(0b00000000);
set_tris_b(0b00000001);
int_count=INTS_PER_SECOND; //used for timer
seconds=0; //clear out variable
time1=15; //counter for time,30 seconds
while (TRUE)
Code here that reads varibles and processes them. NOthing here that
will affect the issue i am seeing.
PostPosted: Mon May 07, 2007 11:34 am     Reply with quote
What is this device ?
nmeyer
PostPosted: Mon May 07, 2007 11:41 am     Reply with quote
It is an Aardvark I2C/SPI interface from TotalPhase. www.totalphase.com. At this point, I have been able to keep the my PIC from locking up by Clearing the SSPEN in the SSPCON1 and then setting it again, at the end of my IF(state==2) . It does not lock up anymore, but i am not sure if this is the best solution.
nmeyer
PostPosted: Mon May 07, 2007 11:43 am     Reply with quote
Sorry. I ment in the IF(state==0x80) in the INT_SSP interupte routine.
PostPosted: Mon May 07, 2007 11:50 am     Reply with quote
See if this errata on the SSP module for the 16F819 applies to your code:
http://ww1.microchip.com/downloads/en/DeviceDoc/80132f.pdf
Also I noticed that you have #use i2c Slave statements sprinkled in your
code, sometimes just a few lines apart. A #use i2c statement remains
in effect until another one seen. This is linear, from top to bottom in
the program. It's not done on a routine by routine basis. You should
clean this up.
nmeyer
PostPosted: Mon May 07, 2007 11:57 am     Reply with quote
Thanks. I never thought that it might be an issue with the chip itself. It looks like that is what is causeing my problem and that i am doing what they suggest. Well, i think i have functional code now. Thanks for the sanity check.
