I use
setup_timer_2(T2_DIV_BY_1 , 255, 1);
and 4 MHZ crystal put the frequency is 30 hz and not 4KHZ which is the right frequence.I use PCM compiler and pic16F777.
What is the problem?????
Posted: Thu May 03, 2007 11:00 am
Do some detective work. Study the ratios of the numbers.
It's running at 30 Hz, but you believe it should be 4000 Hz.
What is the ratio of these frequencies ? It's this:
---- = .0075
4000
Now multiply that ratio by the oscillator frequency that you believe
the PIC is running at:
.0075 * 4000000 = 30000
This implies that the true oscillator frequency is about 30 KHz.
Now look in the PIC data sheet, in oscillator section. Is there a
setting for the internal oscillator that is approximately 30 KHz ?
If so, your PIC is probably configured for that setting. How can
you change it to the desired setting of 4 MHz ? These are the
questions that you must answer.
