Programming the 10F200....??
PostPosted: Mon May 07, 2007 1:13 pm     Reply with quote
I've been using the PCM compiler (14 bit) for some time now, but just recently had a need to program a 10F200 device. Did I read somewhere that a FREE version of the CCS compiler for 12 bit parts is bundled with MPLAB? I can't seem to find that info again :-(!
Jeff
PostPosted: Mon May 07, 2007 1:23 pm     Reply with quote
It's included in MPLAB. During the installation of MPLAB, select "Custom"
installation. Then you'll see a tree of modules that can be installed.
Look under "Third Party Applications" and select the tickbox for
"CCS PCB compiler".
I haven't done this lately. You may also have to download the "plug-in"
from the CCS download page and run it.
