A question about function returning pointers to ram
future
PostPosted: Fri May 04, 2007 10:27 am     Reply with quote
How to have functions returning pointers to ram strings without global arrays?
I mean, a function prototyped as char *myfunction( char value ); returning the ascii representation of the value for the printf( "%s", myfunction(10) );.
myfunction would have to do its work with a global array.
So I declare it, but a long printf( "%s %s %s", , myfunction(10), myfunction(20), myfunction(30) ); would need 3 global arrays.
How about other solutions?
Thank you.
Neutone
PostPosted: Fri May 04, 2007 11:55 am     Reply with quote
What you ask to do with function pointers can not be done on a PIC in an efficient manner.
What information is it that you wish to display? What format do you wish to display it in?
future56
PostPosted: Fri May 04, 2007 1:20 pm     Reply with quote
It´s not function pointers, but functions returning pointers to ram.
I want to convert many variables to a readable format and display them. So if I need to show 100 counts of 5ms, I´d call the convert function passing 100 to it and it returns a pointer to a string containing "500mS".
I can have a function for each kind of variable and just call them using printf when I need.
One solution is allocating many global arrays and pass the variable and array address to the function and it returns the same array address, but I have to take care of array usage myself when many conversions are needed in the same printf (need 8 at some places).
printf( "%s %s %s %s", myfunction( 100, array1), myfunction( 10, array2), myfunction( 200, array3), myfunction( 300, array4) )
There is another problem with printf not liking more than 3 strings, but this will be addressed later.
Maybe there is a clever way to do this.
Thank you.
PostPosted: Fri May 04, 2007 2:57 pm     Reply with quote
This is what the memory handling functions, in memmgmt.c, are designed to handle. When the functon is first called, have it generate a node, using a static variable to store the 'node_t' variable. Then on future calls, work out how long the string needs to be, and use the 'update_node' function, to change the size.
Then when you have finished with the memory, use 'remove_node' to free the space.
Unfortunately, the space has to be pre-allocated, so unless you have other code that also uses the same memory handling ability, you will not save anything. Also, the calls can beccome rather unreliable...
Personally, I'd probably just allocate a static area to hold the returns, or have the calling program, give the function the location it wants the result to be put into.
future
PostPosted: Fri May 04, 2007 6:04 pm     Reply with quote
Ok, I'll have static arrays declared inside each function and see how it goes.
Thank you.
libor
PostPosted: Sat May 05, 2007 2:24 am     Reply with quote
...and what about programmers not liking 3-line-long instructions ? Smile
What is the reason not using separate 'printf's ? You could then even arrange them into a loop using adressable arguments (e.g. an array of strings).
future
PostPosted: Sat May 05, 2007 9:41 am     Reply with quote
I use long printf's to write a whole 16x2 LCD screen, some have 6 fields.
There is not a good reason, it is just a way I found to make the code work.
As I am not a professional programmer I try to write working code and then look how others did the same thing.
I am working on a menu system with about 60 screens, ranging from simple messages, alarms, to char and 3D array editing...
