pic bootloader question -(pc side)
3dfx
PostPosted: Sun Apr 29, 2007 8:01 am     Reply with quote
i m playing with ccs bootloader ,which is in library, on pic16f877a.
in hex file, words were puts in order strangely.
example;
:1000000000308A000D29...
this is a piece of hex codes in hex file.
and these are hex codes in pic
3000 008A 290D ...
there is a rotation on two hex character.
0030 -----> 3000
which program is do this operation? ccs bootloader (pic side) or pc interface? i have never seen code ,which is do this rotaion, on ccs c library.i hope pc interface do it, isnt it?
PostPosted: Sun Apr 29, 2007 8:18 am     Reply with quote
No 'rotation'. This is simply down to the byte order being displayed. Intel Hex, stores the data sequentially, LSB first. The 16bit word values you are showing, are being displayed MSB first, so the contents of the bytes are swapped over. This is simply down to whatever program you are using to display the byte values 'in' the PIC (presumably your programmer software). This is a display artefact, rather than 'real'.
