CAN wake-up (solved)
cooley
PostPosted: Fri Apr 27, 2007 8:03 pm     Reply with quote
The ECAN module has to be in disable mode before issuing the sleep command or the PIC will not wake up.
Has anybody seen this in the datasheet? Did I miss something that significant or is page 325 of the 4685 datasheet that vague?
hope this saves somebody the few hours i spent working this one.
PostPosted: Fri Apr 27, 2007 8:11 pm     Reply with quote
The data sheet says this, in the section on CAN bus registers:
Note 1: To achieve maximum power saving and/or able to
wake-up on CAN bus activity
, switch CAN module in Disable mode
before putting device to Sleep.
cooley
PostPosted: Fri Apr 27, 2007 8:36 pm     Reply with quote
burned by the fine print once again.
ugh!
