Disabling DCHP
sandy wilson
Disabling DCHP
PostPosted: Fri Apr 27, 2007 4:44 am     Reply with quote
I'm currently running the Microchip stack ported over to CCS (by CCS) on the CCS ethernet prototyping board.
What I'm trying to do is, if I have DHCP enabled and the board is connected to a network with no DHCP server I want to disable DHCP.
This is the code that I'm using:
int InitDHCPTask(void)
static TICKTYPE lastTick;
TICKTYPE currTick;
static enum {DHCP_NOT_BOUND_STATE=0,
DHCP_DELAY_STATE=1,
DHCP_BOUND_STATE=2,
DHCP_TIMEDOUT=3,
ETHER_NOT_CONNECTED=4} state=0;
switch(state)
//Initial state is that we are not linked to the DHCP server
case DHCP_NOT_BOUND_STATE:
//Check to see if any Ethernet at all...
if(!MACIsLinked())
//and move into NOT_CONNECTED state
//state = ETHER_NOT_CONNECTED;
printf("\n\rNot Linked");
return 1;
else if (!DHCPIsBound())
printf("\n\rNot bound ");
return 1;
printf("\r\nBound");
return 2;
break; }
and in the main loop
int1 DHCP_Set = FALSE;
int result = 1;
UDP_SOCKET last_rx_socket=INVALID_UDP_SOCKET;
MACAddrInit();
lcd_init();
StackInit();
do
result = InitDHCPTask();
}while (result == 1);
StackTask();
LCDTask();
My problem is this. If I run it as it stands the code tells me that we are not bound and stays in that section of the code i.e. the stack never binds to the Network. If I remove the section
return 1;
the stack does bind and moves onto the infinite while loop. Any suggestions as to what I'm doing wrong and/orany suggestions on a better way to do this.
thanks for any help
Sandyw
frequentguest
PostPosted: Fri Apr 27, 2007 7:47 am     Reply with quote
I'm having some trouble reading your code, but if I'm understanding it correctly, you're expecting the status of DHCPIsBound() to change without calling StackTask().
Note that the the TCP/IP stack only processes requests, incoming or outgoing--that includes DHCP requests, when you call StackTask(). If you hold the processor in a loop without calling StackTask(), there will be no change in the status of the TCP/IP stack.
In the future, post code using the [code] tags to make it much more readable.
sandy wilson
PostPosted: Fri Apr 27, 2007 8:23 am     Reply with quote
Hello frequentguest,
Changed the code to:-
do
StackTask(); <==========Added this
and a way it went and worked a treat. Thanks for your help
Sandyw Razz
