EX_FLOAT.C Compile problem
Jerry R
PostPosted: Wed Apr 25, 2007 9:07 am     Reply with quote
I'm having problems compiling EX_FLOAT.C and my own code when I include input.c. Compile stops at the below point insdie input.c:
#include <ctype.h>
BYTE gethex1() {
char digit;
digit = getc(
Undefined identifier -- getch
Using PCWH v 3.249
I know the problem is super simple, but I don't see it! Help is much appreciated!
PostPosted: Wed Apr 25, 2007 11:42 am     Reply with quote
This will happen if you comment out the #use rs232() statement in
the Ex_Float.c file. If the compiler doesn't have the UART library
code included, then it doesn't know what getch means.
This is the line:
PostPosted: Thu Apr 26, 2007 8:08 am     Reply with quote
PCM programmer:
Thanks for the reply. Yes, I caught that yesterday. What a big DUH!
I appreciate your reply!
