Problems with Port A on a PIC16F877
jfk1965
PostPosted: Wed Apr 25, 2007 1:59 am     Reply with quote
compiler Version 3.245
I have the port set to read adc on channels 0 - 3 using
setup_adc_ports(AN0_AN1_AN3);
as it states in the device header file. This works ok no problems, the problems are that I want to use Pins RA4 + RA5 as outputs to drive an LED. These pins are permantly in the low state even when I use a command
output_high (Pin_A4);
Is there any reason for this that anyone can suggest?
TIA
JFK
PIC_ECM
PostPosted: Wed Apr 25, 2007 2:31 am     Reply with quote
Confirm that you hav'nt set all of port A as an input. That may be the cause of your problem
Carlos.
jfk1965
PostPosted: Wed Apr 25, 2007 2:44 am     Reply with quote
Hi Carlos
No I haven't set it all as input it works fine if I use the MPlab SIM Debugger but doesn't work on an actual pic.
JFK
PostPosted: Wed Apr 25, 2007 3:40 am     Reply with quote
As on most PIC processors pin RA4 is an open-drain output. For example you can add a pull-up resistor to get a high level output voltage. In your case, driving a LED, I would reverse the LED connection and connect the cathode of the LED to the PIC (PIC sinks current i.s.o. sourcing, ouput_low() will light the LED).
Pin RA5 is a normal output and should work as expected.
