CCP1 interrupt not working...
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Sun May 20, 2007 11:26 pm     Reply with quote
Dear Sir,
here i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
for ic programming i am using MPLAB ICD2.so MCLR is external.
in this i am sensing freq. for 337Hz using ccp1 interrupt.
In CCP1 interrupt only i am incrementing(sec_counter++) counter.and in main() function i am compare
that value with counter & increment the another counter(number++).
In lcd_putc function i am displaying the incremented value i.e. number value.
It shows only 0,when i disconneced from MPLAB ICD2,and applid to my setup nothing is displayed on glass lcd.
Also i want to disply in 0.0 format,
so previousely i made changes in printf();function is,
printf(lcd_putc,"\f%5.1w",number);
byte const Digit_Map[10] = {0xFD,0x61,0xDB,0xF3,0x67,0xB7,0xBF,0xE1,0xFF,0xF7};
but it was showing garbage values.
BTW if i decleared sec_counter++ in main() it works fine.
but not in CCP1 interrupt.May be CCP1 not generating interrupt.
so plz tell where i did mistek. following is my short code.
#include<16F913.h>
#fuses INTRC_IO,NOWDT,PUT,/*****/MCLR,PROTECT,NOCPD,NOBROWNOUT,NOPROTECT,NOIESO,NOFCMEN
#use delay(clock=8000000)   // internal clk 8 MHz.
//                                 LCD Configuration                                   //
// Digit segments    A              B              C              D              E              F              G           DP
//                         b7             b6             b5             b4             b3             b2            b1             b0
#define DIGIT1  COM3+6,   COM2+6,   COM0+6,   COM1+6,   COM0+5,   COM3+5,   COM2+5,   COM1+5      // DISPALYS FROM RIGHT SIDE
#define DIGIT2  COM3+7,   COM2+7,   COM0+7,   COM1+7,   COM0+4,   COM3+4,   COM2+4               // DISPALYS FROM RIGHT SIDE
#define DIGIT3  COM3+8,   COM2+8,   COM0+8,   COM1+8,   COM0+3,   COM3+3,   COM2+3               // DISPALYS FROM RIGHT SIDE
#define DIGIT4  COM3+9,   COM2+9,   COM0+9,   COM1+9,   COM0+2,   COM3+2,   COM2+2                  // DISPALYS FROM RIGHT SIDE
#define DIGIT5 COM3+11,   COM2+11,   COM0+11,   COM1+11,   COM0+1,   COM3+1,   COM2+1                  // DISPALYS FROM RIGHT SIDE
#define DIGIT6 COM3+12,   COM2+12,   COM0+12,   COM1+12,   COM0+0,   COM3+0,   COM2+0                  // DISPALYS FROM RIGHT SIDE
#define VLCD_ENABLE 0x10
#define BLANK 0
void init_CPU();
//character                     0         1        2         3        4        5        6         7       8        9
byte const Digit_Map[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xF6};
byte lcd_pos ;
static unsigned int16 sec_counter = 0;
#int_ccp1
void ccp1_isr(void)
   sec_counter++;
void lcd_putc(char c)
  byte segments;
 if(c=='\f')
     lcd_pos=0;
else {
     if((c>='0')&&(c<='9'))
         segments=Digit_Map[c-'0'];
         segments=BLANK;
      switch(lcd_pos)
          case 1:  lcd_symbol(segments,DIGIT6); break;     // fill 1s place
         case 2:  lcd_symbol(segments,DIGIT5); break;      // fill 10s place
              case 3:  lcd_symbol(segments,DIGIT4); break;     // fill 100s place
             case 4 : lcd_symbol(segments,DIGIT3); break;     // fill  1000s place
              case 5 : lcd_symbol(segments,DIGIT2); break;      // fill  10000splace
              case 6 : lcd_symbol(segments,DIGIT1); break;     // fill  10000s place
 lcd_pos++;
long number = 0;
init_CPU();
                  printf(lcd_putc,"\f%6lu",number);
                  if(sec_counter == 10000)
          {   sec_counter = 0;
             if(number++==100000)
               number=0;
void  init_CPU()
/**************  PORT SETTINGS ****************/
   PORT_B_PULLUPS(0XC0);
   SET_TRIS_A(0X80);
   SET_TRIS_B(0XC0);
   SET_TRIS_C(0X27);
   SET_TRIS_E(0X08);
/*************** LCD SETTINGS ********************/
   SETUP_LCD( LCD_MUX14 | LCD_INTRC |VLCD_ENABLE , 2);
/****************  COMPARATOR SETTINGS  ***************/
   SETUP_COMPARATOR(NC_NC_NC_NC);
/****************  INTERRUPT SETTINGS  *****************/
   ENABLE_INTERRUPTS(GLOBAL);
//   ENABLE_INTERRUPTS(INT_TIMER1);      //enable timer1 interrupt
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
setup_ccp1(CCP_CAPTURE_RE);       //Capture on rising edge
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
Thank You,
With Best Regards,
Deepak.
deepakomanna
PostPosted: Mon May 21, 2007 9:20 pm     Reply with quote
can any body help me to solve my above posted query ?
Thank You,
With Best Regards,
Deepak.
PostPosted: Mon May 21, 2007 9:37 pm     Reply with quote
Explain what you're doing with the CCP1 interrupt. Normally, the
CCP1 interrupt is used to read the CCP1 register after it captures the
value of Timer1 on two sequential positive edges at the CCP1 pin.
Then by subtracting the first CCP1 value from the 2nd one, you can
determine the number of Timer1 clocks between two sequential edges
of the input waveform. From that value, you can calculate the period
and the frequency of the waveform. There are examples of this method
posted on the forum.
You're not doing that. The reason no one has replied is because we
don't know what you're doing, or why.
deepakomanna
PostPosted: Mon May 21, 2007 11:03 pm     Reply with quote
thanks for replying sir,
ok,here is the detail description.
To RC5/T1CKI/CCP1/SEG10 (pin no.16 of 16f913) i have connected freq. generator(Square wave).
Here i am want to measure time interval between two rising pulses, to calculate i/p freq.
if the i/p frequency is >= 337Hz .i have to increment "sec_counter".
if the sec_counter incremented 334 times i.e. 1 sec. i have to increment "number".
And that incremented "number" value i have to display on glass lcd(in 5.1 digit format).
Also i want know how to display digits in 5.1 format.
here is my modified code.
#include<16F913.h>
#fuses INTRC_IO,NOWDT,PUT,/*****/MCLR,PROTECT,NOCPD,NOBROWNOUT,NOPROTECT,NOIESO,NOFCMEN   //external MCLR bcz of MPLAB ICD2
#define BLANK 0
void init_CPU();
byte lcd_pos ;
int16 isr_ccp_delta;
unsigned int16 sec_counter;
   byte segments;
 if(c=='\f')
     lcd_pos=0;
else {
         segments=BLANK;
      switch(lcd_pos)
 lcd_pos++;
#int_ccp1
void ccp1_isr(void)
int16 current_ccp;
static int16 old_ccp = 0;
// Read CCP1 register
current_ccp = CCP_1;
isr_ccp_delta = current_ccp - old_ccp;
old_ccp = current_ccp;
   int16 current_ccp_delta;
   int16 frequency;
   long number = 0;
   sec_counter = 0;
   init_CPU();
            printf(lcd_putc,"\f%6lu",number);   // how to display  a decimal point.
            disable_interrupts(GLOBAL);
       current_ccp_delta = isr_ccp_delta;
      // internal freq is 8Mhz, So timer1 clock is 2 MHz ,if i/p freq. is 337 Hz
      //period is about 2997 usec.prescelar is 1:1 for timer1.
      frequency = (int16)(2000000L / current_ccp_delta);
         if(frequency >= 337 )
               sec_counter++;
                     if(sec_counter == 334 )   // to increment "number" after 1 sec.
                           sec_counter = 0;
                           if(number++==100000)   // 5.1 digit display counter.
                             number=0;
void  init_CPU()
   PORT_B_PULLUPS(0XC0);      // RB7 & RB6 i/p for programming devices.
   SET_TRIS_A(0X80);         //
   SET_TRIS_B(0XC0);
   SET_TRIS_C(0X27);         //VLCD 1,2,3 i/p
   SET_TRIS_E(0X08);         // RE3 i/p for programming the device.
         // Setup Timer1 and CCP1 for Capture mode so that
         // we can measure the input signal's frequency.
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
If u need further information plz let me know.
awaiting for ur reply.
Thank You,
With Best Regards,
Deepak.
PostPosted: Mon May 21, 2007 11:26 pm     Reply with quote
You must test and debug your code. I'm not going to do it for you.
