How to determine time for calculation to execute.
edbfmi1
PostPosted: Mon Apr 16, 2007 7:44 am     Reply with quote
I am using a PIC16C76.
I have a fairly complicated math routine to calculate the time delay before turning on an output. The variables in the routine can change depending on input states, programmend variables, etc.
Since these variables can be different every time the calculations are made the time it takes to execute the calculation is different.
Does anyone know a way to see how long it takes to execute a certain part of code on the fly? I can see the different times using the Stopwatch fucntion in MPLAB but I need to be able to get this value into the code so I can subtract if from the final calculation to get a correct delay time.
SherpaDoug
PostPosted: Mon Apr 16, 2007 8:12 am     Reply with quote
How about starting a timer when you collect the data. Then when you are done with the math you read the timer and subtract from your calculated time. Or more likely just let the timer run till it matches your calculated time, then do your I/O. Then you have the precise time between the data collection and the output.
