jma_1
Posted: Mon Apr 16, 2007 6:42 am |
Greetings rblue,
It is unclear from your posting how you are loading the software presently. I would assume you are programming the pic14F877A using a device programmer. There is no difference between using the ICSP and a device programmer other than the ICSP allows debug capabilities.
It sounds like you would like to program serially over RS232. If this is the case, look at the bootloader examples provided with the CCS examples. Also, search for bootloader in the forum for common questions. There are other bootloaders mentioned in the forum and available for the pic.
Cheers,
JMA |
