lost parameter when I call a function
no username
PostPosted: Fri Apr 06, 2007 11:14 am     Reply with quote
Hi folks,
i have a problem with the CCS 3.227. This is my function definition:
void set_rgb(int address, int pwm0, int pwm1, int pwm2)
//code
And in my main.c I have:
set_rgb(1,200,200,200);
But I only get a result for pwm1 and pwm2. It seems that the 2nd parameter get lost. I have renamed the parameter e.g. pwm_0 and I have changed the order of the parameter. Always the 2nd parameter get lost!
I have copyed the code out of the function into the main.c than my code works.
I’m open for all suggestions and recommendations!! thanks
PostPosted: Fri Apr 06, 2007 12:09 pm     Reply with quote
Put a printf statement at the start of the function and display all four
of the parameters. What does it show ?
no username
PostPosted: Sat Apr 07, 2007 9:51 am     Reply with quote
Thanks PCM programmer.
I have used the I2C bus because I don’t use RS232 in my application.
I have removed the code of my function. Now the function is only the I2C report of the parameters.
void set_rgb(int address, int pwm0, int pwm1, int pwm2) {
   i2c_start();
   i2c_write(address);
   i2c_write(pwm0);
   i2c_write(pwm1);
   i2c_write(pwm2);
   i2c_stop();
   delay_us(1000);
When I call the function then I can see all 4 parameters on the I2C bus.
But when I remove the delay_us(1000); then pwm0 is always reported as 0x00 independent from the parameter that I give to the function.
Always the 2nd parameter get lost! Is it a bug in CCS?
PostPosted: Sat Apr 07, 2007 11:05 am     Reply with quote
How do you see the parameters on the i2c bus ? Are you using an i2c
bus monitor ?
Is this project being done using real hardware, or is this being done
in an emulator such as Proteus ?
no username
PostPosted: Mon Apr 09, 2007 5:04 am     Reply with quote
Sorry for the delay. It took some time to isolate failure.
Now my code is:
   pwm0_v=pwm_0;
   pwm1_v=pwm_1;
   pwm2_v=pwm_2;
   i2c_start();
   pwm0_n=pwm_0;
   pwm1_n=pwm_1;
   pwm2_n=pwm_2;
   i2c_write(address);
   i2c_write(pwm0);
   i2c_write(pwm1);
   i2c_write(pwm2);
   i2c_stop();
   delay_us(1000);
pwmx_v and pwmx_n are global variables so I can debug them in the main file. I have debugged the 16F88 with ICD2 with the following main file:
while (1)
The first time in the while loop I see in the watch window:
pwm0_v= pwm1_v= pwm2_v= pwm0_n= pwm1_n= pwm2_n=200
BUT beginning on the 2nd time in the loop I see:
pwm0_v= pwm1_v= pwm2_v= pwm1_n= pwm2_n=200
pwm0_n=0
So for me it seems to be a problem with the build in function i2cstart() starting by the 2nd time it is called.
Can someone test it with the latest CCS version and on a other device? I can send the source files via mail.
PostPosted: Mon Apr 09, 2007 8:26 am     Reply with quote
What if this whole thing is a Watch window problem with ICD2 and your
version of MPLAB ?
Put a printf statement in there, and run the program in standalone mode
(not in Debugger mode). See if the parameters are displayed on the
terminal window in your PC.
Also, post your version of MPLAB.
no username
PostPosted: Wed Apr 11, 2007 2:49 pm     Reply with quote
No it is defiantly a problem in real HW. I have made all the Tests with a standalone 16F88. Only the last test was done in debug mode with MPLAB v7.20.
Today I have tested the program with printf():
   printf("%u ",pwm0);
   printf("%u ",pwm1);
   printf("%u    ",pwm2);
   i2c_start();
   printf("%u ",pwm0);
   printf("%u ",pwm1);
   printf("%u    ",pwm2);
   i2c_write(address);
   i2c_write(pwm0);
   i2c_write(pwm1);
   i2c_write(pwm2);
   i2c_stop();
   delay_us(1000);
The result is the same as in the debug mode. Before i2c_start() I have the correct parameters pwm0, pwm1, pwm2 = 200. After i2c_start() the parameter are pwm0=200, pwm1=0, pwm2=200.
Strange things are going on…
PostPosted: Wed Apr 11, 2007 3:02 pm     Reply with quote
If you can post a very small test program that just calls that routine
and demonstrates the failure, then the problem can likely be found by
examining the .LST file.
By a test program, I mean a program that has the #include statement for the PIC, and also #fuses, #use delay(), and code in main() that demonstrates the problem (or calls the routine that demonstrates it).
The posted code should compile with no errors.
no username
PostPosted: Thu Apr 12, 2007 1:16 pm     Reply with quote
So this is my test program. It is as short as possible. With the CCS Compiler Version 3.227 I can compile the code without errors.
#include <16F88.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                    //Master Clear pin enabled
#FUSES NOLVP                    //No Low Voltage Programming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#use i2c(Master,fast,sda=PIN_B1,scl=PIN_B4)
#use rs232(baud=9600, xmit=PIN_B5, rcv=PIN_B2)
   printf("%u ",pwm0);
   printf("%u ",pwm1);
   printf("%u    ",pwm2);
   i2c_start();
   printf("%u ",pwm0);
   printf("%u ",pwm1);
   printf("%u    ",pwm2);
   i2c_write(address);
   i2c_write(0xA2);
   i2c_write(pwm0);
   i2c_write(pwm1);
   i2c_write(pwm2);
   i2c_stop();
setup_oscillator(OSC_4MHZ|OSC_INTRC);
while (1)
   set_rgb(0b11100010,200,200,200);
   set_rgb(0b11100010,10,10,10);
If it is helpful I can also post the *.LST file. I am looking forward to your results.
Many thanks in ahead!
PostPosted: Thu Apr 12, 2007 1:23 pm     Reply with quote
Post the output of the program that's displayed on your terminal window.
Also tell what pass it fails on. Does it fail on the very first pass through
the while() loop.
no username
PostPosted: Thu Apr 12, 2007 2:05 pm     Reply with quote
In Hyper Terminal I get reported:
    200 200 200 200 200 200 10 10 10 0 10 10 200 200 200 0 200 200
    10 10 10 0 10 10 and so on ...
So the first loop goes well. BUT beginning by the 2nd time in the loop pwm0 becomes 0. pwm0 is the 2nd parameter (1st is address).
