LCD change pins
Phil1
LCD change pins
PostPosted: Wed Apr 11, 2007 7:08 pm     Reply with quote
I'm using PICC , library for lcd . It's working , but I need to change the pins for
b4 enable
B5 rs
B6 rw
B0 D4
B1 D5
B2 D6
B3 D7
Do someone know how to change the pins in the LCD.c library?
PostPosted: Wed Apr 11, 2007 7:36 pm     Reply with quote
Use this driver in the Code Library. It allows you to easily change the pins.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
PostPosted: Wed Apr 11, 2007 7:55 pm     Reply with quote
Thank you very much , it's working
