25XX1024 EEPROM SPI
manel
25XX1024 EEPROM SPI
PostPosted: Tue Apr 10, 2007 3:09 pm     Reply with quote
Anyone know if the driver for the 25xx640 will work with 25xx1024 or can be modified for the 1024. I am trying to connect to pic 16f917.
After reviewing code it seems like it would work. Has anyone done this!
Thanks!
PostPosted: Wed Apr 11, 2007 11:59 am     Reply with quote
The 25LC640 driver won't directly work with the 25LC1024. That's
because the 25LC1024 requires a 24-bit address in the i2c protocol,
but the 25LC640 only uses a 16-bit address. So the driver would
have to be modified.
Also, the 25LC1024 has several new commands that should be added
to the driver.
