Addressing individual bits of a register
andyd
PostPosted: Sat Apr 07, 2007 9:55 am     Reply with quote
What's the syntax to set or clear a particular bit of a register?
I've got the line CCP1CON.5 = 1; to set bit 5 of that register (CCP1CON is already defined as #byte CCP1CON = 0x17), but the compiler doesn't like it (keeps saying I need a ; on that line).
PostPosted: Sat Apr 07, 2007 10:18 am     Reply with quote
#bit DC1B1=CCP1CON.5
You can then just set this to 1' or '0' when required.
DC1B1=1;
or
DC1B1=0;
Alternatively:
bit_set(CCP1CON,5);
bit_clear(CCP1CON.5);
