Dan Guest
| PORTB causing problem on PORTC UART |
Posted: Thu Apr 05, 2007 5:20 pm |
I have a 18F2580 @ 20MHz and the RS232 baud is 115200. My sample program is this :
#include <18F2580.h>
#fuses NOWDT,NOPROTECT,NOLVP,HS
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
char c;
while (true)
c = getc();
putc(c);
putc(c+1);
When pin B5 is low, everything works fine, but when B5 is high, it forces the TX pin to be low. What could cause this? |
Dan Guest
Posted: Fri Apr 06, 2007 12:32 pm |
You were right, my programmer had that fuse set. It works fine now.
Thanks |
