problem of RS232 (CCSC)
progccsc
PostPosted: Thu Apr 05, 2007 8:44 am     Reply with quote
I use this programme to receive 10 data from RS232 and then transmit all the data to PC(RS232). in the same time, affiche to LCD.
But there are always some problem.
if I transmit these data from PC:
30 31 32 33 34 35 36 37 38 39 0123456789
I will receive these data from PIC
39 38 3F 3E 3D 3C 3B 3A 39 38 60 FF 02 FF 00 01 98?>=<;:98`ÿ.ÿ..
FF 00 3C FF 00 38 FF 00 18 FF 40 FF 01 FF 03 FF ÿ.<ÿ.8ÿ..ÿ@ÿ.ÿ.ÿ
18 40 FF 20 FF A1 FF 18
Thanks first for all the helps coming....
#include <18F452>
#fuses HS, NOPROTECT, NOWDT, NODEBUG, NOLVP, PUT
#use rs232(baud=115200,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=d)
#include <LCD_.c>
int8 data[10],i;
lcd_init();
printf(lcd_putc,"CCSC LCD");
for(i=0;i<10>=0;i--)
fputc(data[i],d);
lcd_gotoxy(1,2);
printf(lcd_putc,"%u",data[i]);
delay_ms(500);}
PostPosted: Thu Apr 05, 2007 9:37 am     Reply with quote
Repost your program in a form we can see it (use the 'code' button, and disabl HTML in the post. At present there is nothing even remotely useable being shown...
