fuses description
fuses description
PostPosted: Sun Apr 01, 2007 1:16 pm     Reply with quote
Hello, does description what each fuse means exist?
I mean a list of all the fuses and their meaning, i didn't find it in the CCS manual.
cheers M.
PostPosted: Sun Apr 01, 2007 1:47 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=24336
http://www.ccsinfo.com/forum/viewtopic.php?t=30070
Note that the fuses.txt file mentioned in the 2nd thread is only available
if you have the CCS IDE (PCW or PCWH). You don't get it if you buy
the command line compiler(s).
PostPosted: Wed Apr 04, 2007 3:40 am     Reply with quote
Thank you, I have fuses.txt in my folder.
regards M.
