Seidleroni Guest
How to use multiple UART (or EUSART) |
Posted: Mon Apr 02, 2007 8:01 am |
I'm using the PIC18F2620, and I can use it with my code no problem with the standard receive and transmit pins (C6 and C7), but if I try to use it on two different pins (B5 and B6), it gives me an error on the line:
set_uart_speed(2400);
Is there something else I need to do when switching from the standard hardware UART pins to other pins?
Thanks!
Seidleroni |
Posted: Mon Apr 02, 2007 9:07 am |
With the standard pins (C6 and C7) the compiler will select the internal hardware UART. When you select B5 and B6 the compiler will generate a software UART.
Check the manual, set_uart_speed() is only allowed for changing the baudrate of the _hardware_ UART, it is not allowed for a software based UART.
Read the manual entry for 'set_uart_speed'. Noth that it says:
"Changes the baud rate of the built-in hardware RS232 serial port at run-time".
Note the word 'hardware'...
You cannot change the speed of a 'soft' UART. The software UART, is done by generating specific code for the speed requested.
If you want two speeds on a software UART, then declare two 'streams' on the pins with different baud rates, and select the stream to get the required rate (this results in two separate routines being generated).
