how to define an array, say a[6], in PIC FLASH memory
HB
PostPosted: Wed Apr 04, 2007 8:57 pm     Reply with quote
Dear Sir,
Is there anyway to define an array in PIC FLASH memory such that it can be read from and write to?
Best regards,
hb
PostPosted: Wed Apr 04, 2007 9:05 pm     Reply with quote
If you have vs. 3 of the compiler, look at 'typemod' in the manual.
If you have vs. 4, look at 'addressmod' in the manual.
From the current manual:
CCS C compiler also provides a custom qualifier addressmod which can
be used to define a memory region that can be RAM, program eeprom,
data eeprom or external memory. Addressmod replaces the older
typemod (with a different syntax).
