asm syntax for int16 variables
future
PostPosted: Tue Feb 20, 2007 8:56 am     Reply with quote
I can not manage to access a struct using inline asm
struct
    long deadline;
} bank1;
      INFSNZ  &bank1.deadline,F
      INCFSZ  &bank1.deadline+1,F
Using the *(char*) cast proposed by other threads results in compile time error (Expression must evaluate to a constant).
Thank you.
PostPosted: Tue Feb 20, 2007 10:36 am     Reply with quote
What compiler version?.
You don't actually 'need' the '&' for the first line, but either as posted, or using:
#asm
   INFSNZ  bank1.deadline,F
#endasm
It compiles fine under 3.249, and accesses the right bytes.
future
PostPosted: Tue Feb 20, 2007 11:25 am     Reply with quote
Sorry, it is version 4. Version 3 works fine using the posted code.
On version 4, &var+1 is 2 bytes after var, so the char cast is needed and I can't find the correct syntax for it.
PostPosted: Tue Feb 20, 2007 1:36 pm     Reply with quote
OK.
V4, has switched to correct C syntax, so incrementing a pointer, moves you forward by the size of the addressed object. This will cause problems accessing latter bytes in anything larger than an int, when using assembler using this normal 'trick'.
Use 3.249, and report it to CCS.
Alternatively, declare a union, rather than a structure, and have a second component, talking to the bytes, and access this in the assembler.
bilko
PostPosted: Fri Mar 02, 2007 9:14 am     Reply with quote
This works ... but it's annoying havong to change all my code .... and for all i know it will break with the next compiler version.
I have not found a way of dealing with int32
typedef union {
   int16 w;
   int8  b[2];
} iint16;
#define HI(x) (((iint16)x).b[1])
#ASM
      movf   coil_count,w                      //Low byte
      movf   ((iint16)coil_count).b[1],w   // High byte
      movf   HI(coil_count),w                 // High byte
Bill
bilko
PostPosted: Fri Mar 02, 2007 10:58 am     Reply with quote
.... and this also works
#define   ByteOf(addr,n) (&((int8)addr)+n)
      movwf   ByteOf(acount,2)  //w -> acount+2
PostPosted: Fri Mar 02, 2007 11:08 am     Reply with quote
Now that is neat, and interesting. Totally 'silly', that a syntax that doesn't work inside the assembler, works OK, if it is in a #define.
It appears that the core 'fault', is that the 'cast' doesn't work inside the assembler.
A lovely bodge. Smile
PostPosted: Fri Mar 02, 2007 11:25 am     Reply with quote
I don't know why the word 'spam' appeared in my answer. It appears that something in the filtering on the board, decided the text I had typed, should be replaced by the word 'spam'. I suspect the word I chose, was one that is used in some spam posts. Anyway try 'tidy' instead.
bilko
PostPosted: Mon Mar 05, 2007 10:34 am     Reply with quote
It does work without the #define ... its just easier to use with
PostPosted: Mon Mar 05, 2007 10:46 am     Reply with quote
Yes. What doesn't work inside the assembler, is casting the pointer. You cast the 'value', then generate the pointer. Casting the pointer works outside the assembler.
thomasb
PostPosted: Tue Mar 27, 2007 5:04 pm     Reply with quote
Thanks, it works great! I was scratching my head trying to figure out how to do this. Thank goodness you shared the secrete. Smile
