CAN functions
hawke10500
CAN functions
PostPosted: Mon Mar 26, 2007 6:44 pm     Reply with quote
In the manual there is a CAN functional overview that doesn't show all of the CAN functions and none of the CAN functions are listed in the function listing of the manual. Is there some other document that shows these functions? The manual for the CAN developers kit doesn't show or explain all of the functions in much detail.
Thanks,
Pat
PostPosted: Tue Mar 27, 2007 12:37 pm     Reply with quote
There's some documentation in the comments above each function
in the source files for the CAN functions.
Beyond that, you probably have to look at the CCS example files
that call the functions, look at sample code and explanations posted
in this forum, and read Microchip data sheets and appnotes.
I just looked in the current CCS manual and there is a little explanation
of each CAN function in there. Do a search for 'can_init' and you'll
find the section that shows them all.
