Problems Capturing a pulse's frequency.
zachavm
PostPosted: Fri Mar 23, 2007 12:30 pm     Reply with quote
I'm doing a senior project where that is a DC motor control. Basicly, we are using a speed sensor to read in a speed and then control the input to it to adjust the power accordingly. The speed input is accomplished through reading the frequency of a square wave sent to the pic. Hence, I'm using timer1 in conjunction with CCP1 and it's capture capability.
Currently, I'm trying to get the speed sensor to work and I'm having some problems. In this code, there are a couple of things happening (button inputs, LCD outputs, and use of CCP1 for capturing), but the focus should be on timer1 and CCP1. I've highlighted these sections in the code.
I've spent some time outputting different variables to the LCD and I think I've narrowed the problem down to timer1. Basicly, when I output the value of CCP_1 to the LCD, it always remains the same (65536, the maximum cnt for the timer). I've also been able to determine that the timer1 overflow interrupt is never happening. I don't know what's causing this, but I'm pretty sure that timer1 isn't counting, and I don't know why. I've been using examples, and I can't figure out why this code isn't working? Any suggestions?
#include <16F876.h>
#fuses HS,NOWDT,NOPUT,NOLVP,NOBROWNOUT
#include <string.h>
#include <stdlib.h>
// Global Variables
int i;
int16 speed = 50;
char mystr[10];
int overflow_cnt;
unsigned int32 end_time = 0, start_time = 0;
int32 pulse_ticks;
int32 actual_speed;
int32 cnt = 0;
int b1 = 0;
int b2 = 0;
int screenChanged = 1;
//sends a data byte to the LCD
void send_data(char e)
   output_bit(PIN_C4, 1);  //RS is set high so that the LCD is in Data Mode
   output_B(e);
   delay_us (20);  //Delays for one microsecond
   output_bit(PIN_C5, 1);
   delay_us (20);  //Delays for one microsecond to give the LCD time to read the data
   output_bit(PIN_C5, 0);  //enable is low.  brought high to put on data
   delay_us (20);
//sends a command to the LCD
void send_command(char f)
   output_bit(PIN_C4, 0);  //RS is set low so that the LCD is in Command Mode
   output_B(f); //turns on display and adds cursor, underline, and cursor blink
   delay_us (20);
   output_bit(PIN_C5, 1);  //trows enable low to send command to LCD
   output_bit(PIN_C5, 0);  //enable is brought back to high
   delay_us (20);
#int_TIMER1
TIMER1_isr() //interupt for timer1 overflow
   ++overflow_cnt; //increments when there is an overflow of timer 1
#int_CCP1
CCP1_isr() //interupt for CCP1 activation
   end_time = CCP_1;
   pulse_ticks = (end_time + ((overflow_cnt * 0x10000) - start_time));
   actual_speed = (int32)((float)(60 * 50000000) / (float)(pulse_ticks * 1024));
   start_time = end_time;
   overflow_cnt = 0;
   //initiates the LCD
   send_command(0x0C);
   send_command(0x38);
   send_command(0x01);
   //activate and setup LCD
   delay_ms (100);
   //send to LCD "Hello World"
   send_data('W');
   send_data('e');
   send_data('l');
   send_data('c');
   send_data('o');
   send_data('m');
   send_data('e');
   delay_ms(2000); //2 second delay
   send_command(0x01); //clears the screen
   delay_ms(5);
   //initialization of timer1 and CCP1
   setup_ccp1(CCP_CAPTURE_RE);
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
   enable_interrupts(INT_CCP1);
   enable_interrupts(global);
      //checks to see if button 1 is pressed (speed up)
      if(!input(PIN_C6) && b1 == 1)
         if (speed <2000> 50)
            speed -= 50;
         b2 = 0;
         screenChanged = 1;
      if(input(PIN_C7))
         b2 = 1;
      //makes sure the screen get's refreshed if no button is pushed
      cnt++;
      if(cnt > 100000)
         screenChanged = 1;
      //outputs the speed to the LCD
      if (screenChanged == 1)
         send_command(0x01);  //clears the display
         delay_ms(5);
         sprintf(mystr, "%lu", speed); //converts the int to a character string
         i = 0;  //loop that writes the number to the LCD
         while(mystr[i] != NULL)
            send_data(mystr[i]);
            i++;
         send_data('R');
         send_data('P');
         send_data('M');
         send_command(0xC0); //shift writing position to second line
         sprintf(mystr, "%lu", actual_speed); //converts the int to a character string
            i++;
         send_data('R');
         send_data('P');
         send_data('M');
         screenChanged = 0;
   }  //end while
} // end main
PostPosted: Fri Mar 23, 2007 12:36 pm     Reply with quote
See this thread, which contains sample code to measure the frequency
of a signal by using the CCP.
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
Also see this post which explains how to disable HTML when you make
a post. You need to do that. (Look closely at your posted code).
http://www.ccsinfo.com/forum/viewtopic.php?t=30264&start=1
zachavm
PostPosted: Fri Mar 23, 2007 12:49 pm     Reply with quote
Well, I've figured out part the big part of the problem almost right after I posted this Embarassed (I had been working on this for the last day). If you look at my timer1 setup, I've got it using an external timer rather then an internal one (D'oh). Anyway, I'm now working out the bugs on that.
zachavm
PostPosted: Mon Mar 26, 2007 11:08 pm     Reply with quote
Thanks guys, this worked like a charm. We've now got it up and running. I appreciate the help.
