Sending floating point number using CCS USB HID code
capfelix
PostPosted: Thu Mar 29, 2007 3:22 am     Reply with quote
Currently I'm using CCS USB HID code as the template for my USB related projects. So far, everything is ok and I'm using the code to transmit integer in byte format.
If I want to transmit floating point number, what should I do with the CCS USB HID code? Anything to change?
