problem with i2c comunication
Fabri
PostPosted: Mon Mar 26, 2007 11:06 am     Reply with quote
Hi Everybody,
I'm in trouble with i2c. Only In case of noise the micro stay inside i2c function till wdt timeout.
Is there any way to introduce a timeout on i2c routine to exit before wdt timeout ?
Shall I edit i2c function to do some change ?
Thanks for help and only suggestion about,
Regards,
Fabri
PostPosted: Mon Mar 26, 2007 2:04 pm     Reply with quote
Look at Mark's i2c master code in the Code Library.
http://www.ccsinfo.com/forum/viewtopic.php?t=22105
He has an example of how to handle a i2c bus timeout.
Look for this variable in his code, to find the sections on timeouts:
I2C_Bus_Timeout
Also, for information on hardware fixes for i2c bus noise,
search for this string on Google:
i2c noise OR noisy
Example:
http://focus.ti.com/lit/an/slea053/slea053.pdf
Fabri
PostPosted: Mon Mar 26, 2007 2:55 pm     Reply with quote
Hi PCM,
Thanks for suggestion.
I belive the problem is in software because in #use_i2c there's a test of end of transmission/reception (PIR1,SSPIF) so in case of problem the micro stay in loop till timeout reset occure. At the moment I'll try so solve the problem without rewrite i2c comunication routine.
I've a timer0 interrupt service so I think to set SSPIF manually when timeout occured after i2c operation, just to exit from routine before wdt timeout.
do you think is good way ?
