CPU reset after wake from sleep
Goto page 1, 2  Next
Static
PostPosted: Tue Apr 03, 2007 3:00 pm     Reply with quote
I'm using a 10F200 and attempting to use the sleep and wake on change. However, everytime the chip wakes up from a "wake-on-change" it does a reset and starts from the beginning of code instead of continuing the code after sleep. Any suggestions?
In the following code the "IF" statements do not get executed after a wake on change:
//Sleep Test
//Compiled on IDE version 3.249
#include <10F200.h>
#fuses    NOMCLR,NOPROTECT,NOWDT
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
#byte   OSCCAL = 0x05      //define address of oscillator calibration
short B1,B3;
   set_options(0b01010111);   //enable wake on change and disable pullups
   OSCCAL = 0x00;               //set osccal - disable intosc output
   set_tris_b(0b00001010);      //set GPIO - B0,B2 outputs and B1,B3 inputs
   output_low(PIN_B0);         //set output
   output_low(PIN_B2);         //set output
      B1 = input(PIN_B1);
      B3 = input(PIN_B3);
      Sleep();
      if(!input(PIN_B1))   //button input 1, goes low when pushed
         output_high(PIN_B2);
         output_low(PIN_B2);
      if(!input(PIN_B3))   //button input 2, goes low when pushed
         output_high(PIN_B0);
         output_low(PIN_B0);
I appreciate any advice anyone can give.
kevcon
PostPosted: Tue Apr 03, 2007 3:08 pm     Reply with quote
It's supposed to do that.
Look on page 19 of the datasheet and there is a bit in the STATUS register, GPWUF you have to test it to see what kind of reset it was.
EDIT: That's funny I was going to say the same thing about it being a different than a typical PIC.
Point is read the data sheet over and over and over on this one...
jecottrell
PostPosted: Tue Apr 03, 2007 3:11 pm     Reply with quote
I ran into a similar problem.....
From the data sheet:
9.9.2 WAKE-UP FROM SLEEP
The device can wake-up from Sleep through one of
the following events:
1. An external Reset input on GP3/MCLR/VPP pin,
when configured as MCLR.
2. A Watchdog Timer time-out Reset (if WDT was
enabled).
3. A change on input pin GP0, GP1 or GP3 when
wake-up on change is enabled.
4. A comparator output change has occurred when
wake-up on comparator change is enabled.
These events cause a device Reset.
The 10F parts are a different animal.
John
EDIT: Beat me to it while cutting and pasting. That was going to be the next suggestion... code trickery to make a RESET appear more like a standard PIC wake up.
Static
PostPosted: Tue Apr 03, 2007 3:17 pm     Reply with quote
I attempted to find the cause of reset using the reset_cause() using the following:
      y=restart_cause();
      for(x=0;x<8;++x)
            output_bit(PIN_B0,shift_right(&y,1,0));
         delay_ms(3000);
         output_low(PIN_B2);
But, I only get the /PD and C bits of the STATUS register set. The GPWUF bit doesn't get set. Anybody know why the GPWUF bit won't set when there's a wake on change?
kevcon
PostPosted: Tue Apr 03, 2007 3:22 pm     Reply with quote
Are you using the simulator or running it on a chip?
I went round and round with microchip about the simulator not working correclty for this chip a while back, and I don't know if they ever fixed it.
Static
PostPosted: Tue Apr 03, 2007 3:24 pm     Reply with quote
I'm running it on the chip not a simulator.
Static
PostPosted: Tue Apr 03, 2007 3:40 pm     Reply with quote
I think I understand. Are you telling me that the code for checking the status has to be before the sleep?
Example:
      y=restart_cause();
      GPWUF = bit_test(y,7);
      if(GPWUF)
         output_low(PIN_B0);
      B1 = input(PIN_B1);
      B3 = input(PIN_B3);
      Sleep();
jecottrell
PostPosted: Tue Apr 03, 2007 3:43 pm     Reply with quote
Put the sleep() after you read your inputs.... that should at least give you a working test...
Right now all it does is wake up and go back to sleep before the pins get read.....
John
EDIT: DOH! Beat me to it again.... Yes. Try that, but in your original test program.
Static
PostPosted: Tue Apr 03, 2007 3:50 pm     Reply with quote
It works! Thanks for the help!
kevcon
PostPosted: Tue Apr 03, 2007 6:52 pm     Reply with quote
You might want to go through your code again, you have atleast one potential bug.
OSCCAL = 0x00;
you are writing over the factory OSCCAL value.
Static
PostPosted: Wed Apr 04, 2007 6:15 am     Reply with quote
Yes, I'm purposely writing over the OSCCAL to set bit 0 (FOSC4) to 0. Would it be better to use the #bit instead?
For example:
#bit FOSC4 = 0x05.0
FOSC4 = 0;
I'm unsure which one to use or if one way is better than the other.
kevcon
PostPosted: Wed Apr 04, 2007 6:40 am     Reply with quote
Yes a bit set would be better, that way you won't overwrite the factory OSCCAL value.
Static
PostPosted: Wed Apr 04, 2007 6:48 am     Reply with quote
Is there anyway to save variable data after sleep?
For example, having a variable (like a counter) that gets updated once every push of a button, and keep that variables value, even after sleep or reset.
My counter variable is initialized to 0 at the beginning of the code but sleep is resetting all variables.
kevcon
PostPosted: Wed Apr 04, 2007 7:13 am     Reply with quote
This is just one of the many ways to do this but your should look somthing like this.
Kevin
#include <10F200.h>
#case
#fuses   NOMCLR
#fuses   NOPROTECT
#fuses   NOWDT
void main( void )
   unsigned int8 counter;
   switch ( restart_cause( ) ) {
      case NORMAL_POWER_UP :
         counter = 0;
      case PIN_CHANGE_FROM_SLEEP :
         counter++;
jecottrell
PostPosted: Wed Apr 04, 2007 7:45 am     Reply with quote
No. Not the way you are waking the part.
Read 9.3 in the datasheet.
Goto page 1, 2  Next
Page 1 of 2
