grasspuddle
Garbage sent with software uart |
Posted: Tue Mar 20, 2007 8:16 am |
pic18f452
code:
main.h:
#include <18F452.h>
#device adc=8
#device *=16
#FUSES HS //High speed Osc (> 4mhz)
//#FUSES XT
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#use RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,STREAM=LCD_UART)
#use RS232(baud=2400,parity=N,xmit=PIN_B6,rcv=PIN_B7,bits=8,STREAM=SW_UART)
#include <cMain.h>
//INITIALIZES PIC
void init(void)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
output_float(PIN_B2);
ext_int_edge(H_TO_L);
//enable_interrupts(INT_RDA);
//enable_interrupts(INT_EXT2);
//enable_interrupts(GLOBAL);
output_bit(PIN_D0,1);
output_bit(PIN_D1,0);
init();
while (1)
output_toggle(PIN_D1);
output_toggle(PIN_D0);
printf("OK");
pic connected to max233cpp
siow.exe shows what is being sent:
júOKjúOKjúOK
I'm almost positive that it isn't software, but what on earth could be causing this? |
Humberto
Posted: Tue Mar 20, 2007 9:52 am |
#FUSES LVP
Are you really programming in low voltage mode ?
Why do you redirect the UART output to:
STREAM=LCD_UART
STREAM=SW_UART
If then you use a single printf. This is inconsitent.
Delete the STREAM option or use fprintf and tell the compiler the output you are going to use.
Humberto |
grasspuddle
Posted: Tue Mar 20, 2007 11:32 am |
i'll answer my own question.
the ground to the rs232 connector (pin5) was only ground about 60% of the time. Some third party board I was interfacing with had a pin I thought to be ground switch from ground to something else. Simply putting a wire from pin5 to the ground on my own board fixed the problem. The evil hardware strikes again.
thx for the reply humberto (LVP should've been NOLVP, sry) |
