Problem 'stepping over' in MPLAB
groston
PostPosted: Mon Mar 19, 2007 12:21 pm     Reply with quote
I am new to MPLAB and the CCS compiler, so maybe that which I am about to describe is normal...
Here is my highly sophisticated program:
#include <16F88.h>
#fuses NOWDT,NOPROTECT,INTRC_IO,PUT,NOLVP
#use delay(internal=4M)
   while (1)
      output_bit (PIN_B0, 1);   // break point here
      output_bit (PIN_B0, 0);
Within MPLAB, I have selected the ICD2 as the Debugger and downloaded the program. I then click the 'Run' button and after a brief pause, the indicator shows that execution has paused on the line marked. Here's where things get odd.
When I click the 'Step Over' button, I see about four instances of:
Stepping Target
MPLAB ICD 2 Ready
in the output window. Mildly annoying, but livable. The problem is the next time I click 'Step Over', I get an 'endless' number of these messages. (Obviously the number is not infinite, but close enough.)
As far as I can tell, an instance of:
Stepping Target
MPLAB ICD 2 Ready
is displayed for each line of assembly code.
So, what puzzles me is this: Shouldn't 'Step Over' tell the debugger to 'go do everything needed for this line of code and tell me when you're done' as opposed to what it is doing? Have I simply configured something incorrectly?
I look forward to your suggestions. I switched to MPLAB and CCS so that I could do some debugging and it is not working as one would expect.
Thanks for your help!
Gerald P. Roston
PostPosted: Mon Mar 19, 2007 1:44 pm     Reply with quote
Here is a thread on the topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=27528
