puts sends not all the data???
Jody
PostPosted: Mon Mar 19, 2007 10:34 am     Reply with quote
When I send data whith the puts command I receive only a few characters...??? But when I look at the variabels with the ICD I see that they have the correct data.... what am I missing??
I added the code:
#include "L:\Afstand_schatting\Afstand_Schatting.h"
#include <string.h>
#include <stddef.h>
#include <stdlib.h>
#include <input.c>
#define  HARTBEAT                   PIN_D0
#define  POLY                       0x0107
#define  CRC_INIT                   0x00
typedef unsigned char   CRC_TYPE;
int1                    string_ready   = FALSE;
BYTE                    next_in        = 0;
char                    string[45];
char                    string_copy[45];
char                    delimiters[2];
char                    *ptr;
char                    objectnr[1];
char                    cmd[10];
char                    arg1[6];
char                    arg2[6];
char                    arg3[6];
char                    arg4[6];
int16                    crc_calculated;
char                    crc_received[2];
#int_RDA
RDA_isr()
   string[next_in]=getc();
   if(string[next_in] == '\n')   //Einde string
     string[next_in] = '\0';
     output_toggle(HARTBEAT);
     string_ready = TRUE;
   next_in=(next_in+1);
int8 lengte       = 0;
int16 i            = 0;
   setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM at RC2
   setup_ccp2(CCP_PWM);   // Configure CCP2 as a PWM at RC1
   setup_ccp3(CCP_PWM);   // Configure CCP3 as a PWM at RG3
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_spi2(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,255,1);
   setup_comparator(F6_F5_F4_F3_OUT_ON_F2_F1);
   setup_vref(FALSE);
   enable_interrupts(INT_RDA);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   set_pwm1_duty(200);
   set_pwm2_duty(800);
    /*  for(i = 0; i<1023> 55)
       next_in =0;
      if(STRING_READY == TRUE)
         STRING_READY = FALSE;
         lengte = STRLEN(string);
         lengte = lengte - 3;
         strncpy(string_copy, string, lengte);
         string_copy[lengte] = '\0';
         crc_calculated = generate_8bit_crc(string_copy, lengte-1, 0x107);
//         printf("Calculated CRC: %x\n",crc_calculated);
         puts(crc_calculated);
         strcpy(delimiters," ");
         ptr = strtok (string, delimiters);
         strcpy(objectnr,ptr);
         puts(objectnr);
//printf("Objectnummer:\n");
         ptr = strtok (0, delimiters);
         strcpy(cmd,ptr);
//printf("Command:\n");
         puts(cmd);
         strcpy(arg1,ptr);
//printf("Argument1:\n");
         puts(arg1);
         strcpy(arg2,ptr);
//printf("Argument2:");
         puts(arg2);
         strcpy(arg3,ptr);
//printf("Argument3:\n");
         puts(arg3);
         strcpy(arg4,ptr);
//printf("Argument4:\n");
         puts(arg4);
         strcpy(crc_received,ptr);
//printf("Crc_received:\n");
         puts(crc_received);
         next_in = 0;
