Mr.NewbiePIC Guest
Interrupt on change PORTA for PIC16F687 |
Posted: Mon Mar 19, 2007 3:43 pm |
Hi I'm having a problem of getting an interrupt on change for PORTA (specifically pin RA4) to work. I tried to follow the example from CCS manual but that still didn't work.
I sincerely appreciate any help.
My code is as following
unsigned int8 last_a;
unsigned int8 port_a;
#int_RA
void RA_isr()
unsigned int8 changes;
port_a = input_a();
changes = last_a ^ port_a;
last_a = port_a;
if (bit_test(changes,4)&& !bit_test(last_a,4))
//b4 went low
SleepMode = 0;
delay_ms (100); //debounce
//PIC_INTCON &= ~PIC_INTCON_RABIF;
//clear_interrupt(INT_RA);
/* Input-Output for Each Port */
set_tris_a( 0x10 );
set_tris_b( 0xFF );
set_tris_c( 0x00 );
/* Enable Interrupt on PIN_A4 and PIN_B7 */
PIC_IOCA = 0x10;
//PIC_INTCON |= PIC_INTCON_RABIE;
enable_interrupts(INT_RA);
SleepMode = 1;
port_a = 0;
last_a = 0;
setup_oscillator(OSC_8MHZ);
/* port C is for LED stuffs */
#use fast_io (C)
output_bit(LED0,0);
output_bit(LED1,0);
output_bit(LED2,0);
output_bit(LED3,0);
if(SleepMode) {
output_bit(LED2, 0);
delay_ms(300);
output_bit(LED2, 1);
delay_ms(300);
//sleep();
} else {
output_bit(LED0, 0);
delay_ms(300);
output_bit(LED0, 1);
delay_ms(300);
It seems like when apply L->H for pin RA4 (using a switch), I see that the blinking pattern from LED2 stops, but I don't see the blinking pattern from LED0. But when I have it from H->L (flip the switch the other side) I see that the LED2 blinks again, which puzzled me because it looks as though the interrupt routine got stuck but never got out and the SleepMode never get set back to 0 ( , not too sure though) |
Posted: Mon Mar 19, 2007 8:54 pm |
SleepMode = 1;
port_a = 0;
last_a = 0;
I didn't look at your code in detail, but there are some problems
with the code above. You're enabling interrupts before you initialize
all your global isr flags and variables. You need to init your globals
first, and then enable interrupts. Also, you should use the CCS
clear_interrupt() function to clear INT_RA before you enable global
global interrupts. That way, if the INT_RA flag happened to be set
ahead of time, you won't get a spurious interrupt. You should also
read PortA to clear any "change condition" that may be set, before
you do any of the above. |
