Software pwm more explanation please
atlantis
PostPosted: Thu Mar 15, 2007 2:54 pm     Reply with quote
Can somebody please explain how I set the software pwm code in the following post to generate a certain frequency?
http://www.ccsinfo.com/forum/viewtopic.php?t=20050
As it is it generates 100Hz, now I need it to generate frequencies between 67 and 1750Hz.
Regards
Martin
PostPosted: Fri Mar 16, 2007 11:38 am     Reply with quote
You can change the frequency by changing the LOOPCNT value,
and also the RTCC_DIV_x value.
If the width value = LOOPCNT, then you have 100% duty cycle.
So when you reduce the LOOPCNT value to increase the PWM
frequency, your resolution (number of available steps) will go down.
That's the trade-off.
