4.029 and ICD2
kevcon
4.029 and ICD2
PostPosted: Thu Mar 15, 2007 1:46 pm     Reply with quote
Has anyone upgraded to version 4.029 and having problems with their ICD2?
I can't even run a simple program now
#include "18F65J10.h"
#case
#fuses DEBUG         //Enable Dedicated Debugger Pins
#fuses NOWDT         //Disable Watchdog Timer
#fuses STVREN         //Enable Stack Over/Underflow Reset
#fuses NOXINST         //Disable Extended Instructions
#fuses NOPROTECT      //Disable Code Protection
#fuses NOIESO         //Disable Two Speed Start-up
#fuses FCMEN         //Enable Fail Safe Clock Monitor
#fuses PRIMARY         //Set Defaul Clock as PRIMARY
#fuses H4_SW         //High Speed Crystal and PLL
#fuses WDT32768         //Set WDT Postscaler to MAX
#fuses CCP2C1         //ECCP2/P2A is Multiplexed with RC1
#use delay( clock = 29,491,200, crystal = 7,372,800 )
void main( void )
But if I do an assembly program with MPASM it works fine.
PostPosted: Thu Mar 15, 2007 1:52 pm     Reply with quote
Do you mean the Microchip ICD2 or the CCS ICD-U40 ?
This program won't do anything. It will just go to sleep.
kevcon
PostPosted: Thu Mar 15, 2007 2:04 pm     Reply with quote
MicroChip ICD2
I know, that's it suppossed to do, but it won't even do that.
It programs that part then tries to run and spits out about 10 errors.
But if I do and assembly language program in MPASM everything works fine.
I did have any problems yesterday when I was running 4.027 and I up graded today to 4.029 and now it doesn't work.
I just tried installing 4.027 over 4.029 but it have any effect, I'm going to delete and reinstall and see if that has any effect.
Martin Berriman
PostPosted: Thu Mar 15, 2007 4:16 pm     Reply with quote
Well 4.029 works with ICD-U40...
kevcon
PostPosted: Fri Mar 16, 2007 11:51 am     Reply with quote
Well, I don't what is causing it but I know how to fix it.
If I copy the files in to a new project or recreate a project over the existing one the problem goes away.
The must be something slightly different between projects created in 4.027 and 4.029.
Kevin
