How to declare 64 bit float in PIC16F877A?!?!?!?!?
mugheesahmed
PostPosted: Wed Mar 14, 2007 8:17 am     Reply with quote
hello everybody!!!
Is there anyway that i could declare a 64 bit floating point number in a PIC 16F877A ?!?!?!?!?!?!?!?
32 bit float is not enough to store the decimal places of 7 and above which i actually need....is there any library i could use or sumthing..???
need help urgently...
Mughees
Humberto
PostPosted: Wed Mar 14, 2007 9:09 am     Reply with quote
Double precision is not allowed in CCS.
Are you going to store such a big values in floats ?
Humberto
PostPosted: Wed Mar 14, 2007 9:49 am     Reply with quote
actually it is not a big value...
its something like this
'0.00000021341'
i need the digits after the sixth zero after the decimal...these digits are not stored in a 32 bit floating point number...so actually i needed more precision...
is there a way to solve this directly or indirectly???
where else can i store it then?? :/
Humberto
PostPosted: Wed Mar 14, 2007 10:32 am     Reply with quote
They should.
0.00000021341 = 0x686525B2
Could you point us the range of the values that you need to handle and store ?
Could you pls be more explicit about your procedure to store these values ?
Humberto
