ahmad
Need help for pwm |
Posted: Fri Mar 09, 2007 3:43 am |
I write the following program to generate pwm and there is no output 0n rc2/ccp1 pin ,any body help me.
#include <16F877A.h>
#fuses HS
#fuses NOWDT
#fuses NOPROTECT
#fuses NOLVP
#fuses NODEBUG
#fuses NOPUT
#fuses NOBROWNOUT
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#pragma zero_ram
#define motora PIN_B7
set_tris_c(0b00000000);
setup_timer_2(T2_DIV_BY_16,255,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(1023);
setup_vref(FALSE);
// TODO: USER CODE!!
Posted: Fri Mar 09, 2007 4:54 am |
Two things:
Unless you add:
while (TRUE);
at the end of your code, the processor will go to sleep, and no output at all will occur.
Second, you need a lower duty cycle, to see any pulse.
Set_pwm1_duty(512L);
will give a square wave, which will be easier to see. The 'L', is not necessary with 512 (since it is above 255), but ensures that the code 'sees' a 'long', no matter what value is given, and treats the number as such.
