I tried i2c communication between 18F2420 / Master/ and 18F4420 / Slave/. It doesn't work. I used ex_slave.c code for slave and standard master code. When I used on slave side 16F877A, communication worked properly.
Tried anyone i2c with these new procesors? /18F4420, 18F2420/.
//My I2C buffer
#define BSIZE 32;
//Note buffer size must be binary multiple
int8 buffer[BSIZE];
#define read_i2c() (SSPBUF)
#define write_i2c(x) SSPBUF=(x)
#define MWLBA ((S==1)&&(RW==0)&&(DA==0)&&(BF==1))
#define MWLBD ((S==1)&&(RW==0)&&(DA==1)&&(BF==1))
#define MRLBA ((S==1)&&(RW==1)&&(DA==0)&&(BF==0))
#define MRLBD ((S==1)&&(RW==1)&&(DA==1)&&(BF==0))
#define MNACK ((S==1)&&(RW==0)&&(DA==1)&&(BF==0))
//Note that for the 18 chips, you could add GCEN as another bit to test
#int_SSP
void SSP_int_handler(void) {
static int8 ctr;
int8 tmp;
if(MWLBA) {
//Here I have an address match for a write operation
ctr=0;
tmp=read_i2c();
else if(MWLBD) {
//Here data arriving from master
buffer[ctr++]=read_i2c();
ctr &= (BSIZE-1);
//Limit buffer counter to buffer size
else if(MRLBA) {
//Here an address match for a read command
ctr=0;
write_i2c(buffer[ctr++]);
else if(MRLBD) {
//Here sending data to master
ctr &= (BSIZE-1);
else if(MNACK) {
//Here NACK from master
SSPEN=0;
SSPEN=1;
//Reset I2C module
if (SSPOV) SSPOV=0;
if (WCOL) WCOL=0;
[/code]
Posted: Sun Mar 18, 2007 1:00 pm
Look at initialisation.
On the latter chips, the I2C hardware, is often multiplexed with other peripherals, and/or, may require specific fuses to set which bits are used. This initialisation needs to be right if the peripheral is going to work.
