18F6520
nina
18F6520
PostPosted: Fri Jul 06, 2007 5:48 am     Reply with quote
I want use PIC 18F6520 and I would like know if my code below is ok.
When I compile there are no errors but when I simulate on my lcd just appear 00000.
tks
nina
#include <18F6520.h>
#device ADC=16
#FUSES HS, NOPROTECT, NOPUT, NOBROWNOUT, NOWDT, NOCPD
#include <flex_lcd.c>
#use fast_io (A)
#use fast_io (B)
#use fast_io (D)
float pot,r,t,b;
setup_port_a(ALL_ANALOG);
setup_adc_ports(ALL_ANALOG);
do{
set_adc_channel(0);
pot=read_adc();
r = pot*5;
t = r/4096;
b = (t*260/5);
if (b > 100)
output_high(PIN_D0);
if (b < 100)
output_low(PIN_D0);
lcd_gotoxy(1,1);
printf(lcd_putc,"Shunt: %f",b);
}while(true);
PostPosted: Fri Jul 06, 2007 2:27 pm     Reply with quote
Here's a demo program to display the voltage on pin A0 on an LCD.
Use it as a guide to writing your own program.
http://www.ccsinfo.com/forum/viewtopic.php?t=28842&start=7
The program that you posted has several problems.
1. It's missing the NOLVP fuse.
2. You enable global interrupts, but you don't have any need to do
this, because you don't have an interrupt service routine.
3. You enable "fast_io" mode for port D, but then you don't have a
statement to set the TRIS for port D. But in fact, there is no need
for fast_io mode to be declared in your program at all.
4. You have "#device ADC=16" specified, but this will left-justify the
10-bit result from the A/D. In other words, the result will be
multiplied by 32. I don't know why you're doing this. I didn't
try to understand your math. My suggestion is just look at the
example in the link above.
5. There are other minor issues, such as you're setting the adc channel
inside the do-while() loop. You don't need to do this. You're always
using the same channel, so you could just set it one time, before you
enter the loop.
