lcd problem
hadeelqasaimeh
lcd problem
PostPosted: Sat Mar 31, 2007 3:42 pm     Reply with quote
hi all
i used to use an lcd library called "lcd_kbd1" but i find this library don't work with 18f devices...so i try to use lcd.c ,,it work,,but some characters dissapeard ,,,and its not clear how to write on line 1 or on line 2..
pcm i see your driver flex_lcd.c but it dose not run!...and again idont understand how to choose line
here is my test code:
#include <18F452.h>
#include <flex_lcd.c>
//#include <lcd.c>
{  int value;
   lcd_init();
   set_tris_b(0xff);
   value=input_b();
   lcd_putc('\f');
   printf(lcd_putc,"value is:%x",value);
   lcd_putc('\n');
   printf(lcd_putc,"HELLO");
and here is my old driver....i dont know if you can correct it to work with 18f devices:
#include <jonsinc.h>
// These defines are specifically for a 4x16 line display.
#define LINE_16_1          0x00
#define LINE_16_2          0x40
#define LINE_16_3          0x10
#define LINE_16_4          0x50
// These defines are specifically for a 4x20 line display.
#define LINE_20_1          0x00
#define LINE_20_2          0x40
#define LINE_20_3          0x14
#define LINE_20_4          0x54
// Another define for use in LCD_PutCmd
#define CLEAR_DISP      0x01
// This is a macro used in the subroutines below */
#define     PULSE_EN        EN = 1; delay_us ( 10 ); EN = 0; delay_ms ( 5 )
#byte   port_e  =   9           /* set variable that maps to memory */
#byte   PORT_A  =   5           /* set variable that maps to memory */
#byte   port_b=   6
#byte   PORT_D=   8
#byte   DATA = PORT_A
#bit    RS = port_e.0
#bit    EN = port_e.1
char kbd_getc(void);
char getkey ( void );
// These are prototype statements.
void LCD_SetPosition ( char cX );
void LCD_PutChar ( char cX );
void LCD_PutCmd ( char cX );
void LCD_Init ( void );
// These are the display subroutines.==============================
    // Initializing into 4-bit mode is a very exact sequence
    // as defined in the datasheets for these displays.
    set_tris_a ( 0x00 );        /* outputs */
    set_tris_b ( 0xFC );        /* Bits 0 & 1 are outputs */
    set_tris_e ( 0xF0 );
    DATA = 0x00;
    delay_ms ( 200 );       /* wait enough time after Vdd rise */
    RS =0;
    DATA = 0x03;            /* init with specific nibbles to start 4-bit mode */
    PULSE_EN;
    PULSE_EN;
    PULSE_EN;
    DATA = 0x02;            /* set 4-bit interface */
    PULSE_EN;               /* send dual nibbles hereafter, MSN first */
    LCD_PutCmd ( 0x2C );    /* function set (2 lines, 5x7 characters) */
    LCD_PutCmd ( 0x0E );    /* display ON, cursor on, no blink */
    LCD_PutCmd ( 0x01 );    /* clear display */
    LCD_PutCmd ( 0x06 );    /* entry mode set, increment */
void LCD_SetPosition ( cX )
    This subroutine works specifically for 4-bit Port A.
    Value received cX will place cursor at a particular line and offset.
                   16-char display   20-char display
    Line 1 is hex:     00 - 0F           00 - 13
    Line 2 is hex:     40 - 4F           40 - 53
    Line 3 is hex:     10 - 1F           14 - 27
    Line 4 is hex:     50 - 5F           54 - 67
    DATA = swap ( cX ) | 0x08;
    PULSE_EN;
    DATA = swap ( cX );
    PULSE_EN;
void LCD_PutChar ( cX )
    /* this subroutine works specifically for 4-bit Port A */
    RS = 1;
    DATA = swap ( cX );     /* send high nibble */
    PULSE_EN;
    DATA = swap ( cX );     /* send low nibble */
    PULSE_EN;
    RS = 0;
void LCD_PutCmd ( cX )
    PULSE_EN;
    PULSE_EN;
/* Include this file by inserting the line "#include <jonsinc.h>" at
the beginning of the C source code.  Or, if you prefer, you can embed it's
contents at the end of each of your 12C509H, 16F84H, 16F874.H, etc. files.*/
#case
#ifndef TRUE
#define TRUE 1
#ifndef FALSE
#define FALSE 0
#ifndef YES
#define YES 1
#ifndef NO
#define NO 0
#ifndef HIGH
#define HIGH 1
#ifndef LOW
#define LOW 0
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
#ifndef UP
#define UP 1
#ifndef DOWN
#define DOWN 0
#ifndef UCHAR
#define UCHAR char
#ifndef UINT
#define UINT long
#ifndef BIT
#define BIT short
#ifndef SCHAR
#define SCHAR signed int
#ifndef SINT
#define SINT signed long
#ifndef FLOAT
#define FLOAT float
thank you so much
PostPosted: Sat Mar 31, 2007 4:30 pm     Reply with quote
#byte port_b = 6
#byte PORT_D = 8
These register addresses are different for the 18F452. Look in the
18F452 data sheet to find the correct register addresses.
Look in the section on: SPECIAL FUNCTION REGISTER MAP
There will be a table of register addresses in that section.
hadeelqasaimeh
PostPosted: Sat Mar 31, 2007 5:04 pm     Reply with quote
i will try...thank you
