Rotary Encoding for Amateurs
sonicfire
PostPosted: Mon Feb 26, 2007 1:19 pm     Reply with quote
Does anybody have experience with rotary encoders for measuring a motor's rotational speed? I'm using a slotted-optocoupler as a rotary encoder to help me determine a dc motor's speed. The optocoupler delivers about 2V with no obstruction and about 0V when it's blocked. I could probably use an amplifier to make it 5V output if necessary. At any rate, I was wondering how I could write a reliable speed measurement program for the PIC 16F877. Does anyone know where there's some example code?
Thanks!
jma_1
PostPosted: Tue Feb 27, 2007 9:07 am     Reply with quote
Greetings,
A frequency example, 'EX_FREQC.C', ships with the CCS compiler (examples folder). I would include external circuitry to ensure the correct digital state (2V slightly low and will probably be indeterminate for a level change).
Consideration -> if your motor is stalled or not moving, the timer rollover conditon might need to checked
Cheers,
JMA
kd5uzz
Interesting shaft encoder system.
PostPosted: Wed Feb 28, 2007 4:23 pm     Reply with quote
This doesn't help you with code, but it is a neat system.
I think I'm going to employ something similar to this in my next project...
http://www.seattlerobotics.org/encoder/200109/dpa.html
