Help in AD7714 Driver
joven
PostPosted: Fri Feb 23, 2007 11:27 am     Reply with quote
Hi
I need make the driver for AD7714, for school project.
I have change the driver of AD7705 for control AD7714.
Is the first time i make a driver for SPI.
Driver:
// AD7714.c
//// Driver routines for the AD7714 chip
//Assuming a 4.9152 crystal ocsillator is used between MCLK IN and MCLK OUT
//connection pins to the PIC
#define ADC_DRDY  PIN_B1
#define ADC_DO    PIN_B2
#define ADC_DI    PIN_B3
#define ADC_RESET PIN_B4
#define ADC_CS    PIN_B5
#define ADC_CLK   PIN_B6
//Operation modes (MD1, MD0 bits in Setup Register)
#define ADC_NORMAL 0x00
#define ADC_SELF 0x20
#define ADC_ZERO_SCALE 0x40
#define ADC_FULL_SCALE 0x60
//Gain settings (G2, G1, G0 bits in Setup Register)
#define ADC_GAIN_1      0x00
#define ADC_GAIN_2      0x04
#define ADC_GAIN_4      0x08
#define ADC_GAIN_8      0x0C
#define ADC_GAIN_16     0x10
#define ADC_GAIN_32     0x14
#define ADC_GAIN_64     0x18
#define ADC_GAIN_128    0x1C
//// burnout  corrente
#define ADC_BURNOUT_ON   0x02
#define ADC_BURNOUT_OFF  0x00
//Fsync (FSYNC bit in Setup Register)
#define ADC_FSYNC_RESET 0x01
#define ADC_FSYNC_START 0x00
// Function prototypes
void adc_init();
void setup_adc_device(int mode, int gain, int buffer, int fsync);
void write_adc_byte(BYTE data);
long read_adc_word();
long read_adc_value();
//initialization routine
void adc_init()
   output_low(ADC_RESET);    // Reset all ADC registers to their default state.
   delay_ms(10);
   output_high(ADC_RESET);
   // See Fig. 17 of AD7714 datsheet
   output_high(ADC_CLK);     // CLK line at high state
   output_high(ADC_CS);      // CS line at high state
   setup_adc_device(ADC_SELF,ADC_GAIN_1,ADC_BURNOUT_ON,ADC_FSYNC_START);
   delay_ms(10);
//setup the device paramaters
void setup_adc_device(int mode, int gain,int buffer, int fsync)
   int8 temp1;
     write_adc_byte( 0x10 ); //Communications Register set to write of Setup Register
   temp1 = mode|gain|buffer|fsync;
   write_adc_byte( temp1 ); //Setup Register info here
   int8 i;
   output_low(ADC_CS);
   for(i=0; i<8; i++)
      output_low(ADC_CLK);
      delay_us(50);
      output_bit(ADC_DI, shift_left(&data,1,0));
      delay_us(50);
   int8 i;
   long data;
   output_low(ADC_CS);
   for(i=0; i<24; i++)
      delay_us(50);
      shift_left(&data,2,input(ADC_DO));
      delay_us(50);
   return data;
// read an adc value from the channel 1
   long value;
   while ( input(ADC_DRDY) ); // Loop until data is ready
   write_adc_byte(0x58);   //communications register set to read AIN1
   value=read_adc_word();
   return value;
Exemple:
#include "lcd.c"
#include <ad7714.c>
void main (void)
   int dig=0;
   long value;
   TRISD=0b00001000;
   TRISB=0b10000111;
   adc_init();
   printf(lcd_putc,"\f ola");
   delay_ms(2000);
   printf(lcd_putc,"\f");
      value=read_adc_value();  // Read AIN1 inputs
      printf(lcd_putc,"\f %lu ",value);
I have only configuration one channel. When i try read the adc the function stay in loop until data is ready.
Someone can help-me?
bloureiro
PostPosted: Mon Feb 26, 2007 5:12 am     Reply with quote
Hi
Can you see in http://www.mcu-bg.com/mcu_site/viewtopic.php?p=16057#16057
