18f4520 : EXT interrupt not working
josedebrest
PostPosted: Mon Feb 26, 2007 5:15 am     Reply with quote
Hello, I'm new to CCS compiler and I don't understand why my code dont work (it's on a picdem2 board). I tried to get an external interrupt when pressing a button which is connected to RB0. the strangest thing is that if i put the interrupt on rb1 it is working.
Tanks for your answer
J.M.
#INT_EXT
void ext_isr(void)
    output_high(PIN_B2);
output_drive(PIN_B0);
output_low(PIN_B0);
input(PIN_B0);
  ext_int_edge(0,L_TO_H);      // init interrupt triggering for button press
   enable_interrupts(INT_EXT);// turn on interrupts
output_drive(PIN_B1);
output_drive(PIN_B2);
while(1){
    output_bit(PIN_B1,input(PIN_B0));
PostPosted: Mon Feb 26, 2007 12:42 pm     Reply with quote
I revised your program to clean it up, but it still doesn't work.
The reason is that PicDem2-Plus has an LED on Pin B0.
So even though the push-button switch circuit has a 4.7K pullup
on Pin B0, the forward voltage drop of the LED holds the pin
at about 2.0v. This is too low. It never allows the External
interrupt input on the PIC to reach a "logic high" level.
Therefore the External interrupt is never going to be triggered.
If you pull off the jumper to the LEDs and then measure the
voltage levels with a voltmeter, then it will work. It's not as
convenient (or fun) as with the LEDs, but at least you can see
that it works.
It's unfortunate the the PicDem2-Plus board is built this way.
Also, I noticed that on the very latest version of that board,
called the "Rohs update", that Microchip has changed the
circuits quite a bit. They've moved pushbutton S3 from
pin B0 to pin B1. What were they thinking ? You don't mess
with a demo board. Now all programs written for the PicDem2-Plus
won't work anymore. People will now have to have two versions,
based on the board revision. That, and the new power enable
pin on the LCD and the fact that the new LCD's busy flag is
not readable. I don't know.... What is up with Microchip ?
Who is the project manager on this thing ? They've gone off
into space.
#include <18F452.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#INT_EXT
void ext_isr(void)
ext_int_edge(0, L_TO_H);
clear_interrupt(INT_EXT);
   output_bit(PIN_B1, input(PIN_B0));
