Hi
It was working before but now(after reinstalling the WINDOWS XP) the pcm compiler does not know the 16f690part. I use MPLAB with pcm and pch all together. The 16f688 it knows. What is the problem?
Thanks Brano
Posted: Fri Feb 23, 2007 4:04 pm
Make sure you re-install a version of the CCS compiler that supports
the 16F690. Also, make sure you re-install a version of MPLAB that
supports it.
