whung.john Guest
| the time isnt right? |
Posted: Mon Feb 19, 2007 10:55 pm |
hi!
today i will be make a seccond time model in my program.
but i calculated follow as .i tested counter timer fast .i check really time.
my model have question.
have body can teach me .where is error ? tHK u
#include <16F877.h>
#use delay(clock=10000000)
#fuses NOWDT,HS,NOLVP,BROWNOUT
#include <LCD>
#define CLK_74164 PIN_C3
#define D0_74164 PIN_C1 /
#define CLR_74164 PIN_C2
unsigned int j=0,sec1=0,min1=0;
const char a[]={0x80,0xeb,0x4c,0x49,0x2b,0x19,0x38,0x8b,0x08,0x0b,0xff};
void write_74164(BYTE eo) {
BYTE i;
for(i=1;i<=8;++i) { // Clock out bits from the eo array
if((((eo))&0x80)==0)
output_low(D0_74164);
output_high(D0_74164);
shift_left(&eo,1,0);
output_low(CLK_74164);
output_high(CLK_74164);
#int_timer0
void timer0_isr()
set_timer0(100);
j++;
if (j==1000)
sec1++;
j=0;
lcd_gotoxy(1,2);printf(lcd_putc,"\nnow sec:=%u",sec1);
if (sec1==60)
{ min1++;
sec1=0;
write_74164(a[min1]);
void init74164(void)
output_low(CLR_74164);
DELAY_MS(100);
output_high(CLR_74164);
output_low(CLR_74164); //clock l
output_high(CLR_74164);//clock h
unsigned int i;
init74164();
lcd_init();
write_74164(0xf7);
i=0;
do
write_74164(a[i]);
lcd_gotoxy(1,1);printf(lcd_putc,"now number:=%u",i);
delay_ms(300);
i++;
while (i<11);
write_74164(a[10]);
setup_counters(rtcc_internal,rtcc_div_16);
enable_interrupts(int_timer0);
enable_interrupts(global);
//output_low(CLR_74164);
WHUNG.JOHN Guest
| I FIND LCD DISPLAY DELAY QUESTION! |
Posted: Tue Feb 20, 2007 11:40 am |
HI:PROGRAMMER SIR
i have read u suggest on post information.
and i find my program have some area that the same question.
i have modified finish.but i calculate timer0 counter still very fast .
and I have checked time still have question.
sir ,please direct error area.
i calcuate method follow as ;
because i use 10MZ clock,so i calcuate is => 1/10MZ/(4*16)=6.4us
i want to get a second. so i calcuate is => 1ms=1000us
1000us/6.4us=156 ticks and check calcuate 156*6.4us=998.4us
the 998.4us is very the same 1ms value number for my use .
i modified my program.please tell me my think where is bad.
my modified in here.follow as
#include <16F877.h>
#include <LCD>
#int_TIMER0
void TIMER0_isr(void)
set_timer0(100);
j++;
if (j==1000)
sec1++;
j=0;
BYTE i;
for(i=1;i<=8;++i) {
DELAY_MS(100);
init74164();
lcd_init();
setup_counters(RTCC_INTERNAL,RTCC_DIV_16);
write_74164(0xf7);
lcd_gotoxy(1,2);printf(lcd_putc,"\fnow sec:=%u",sec1);
if (sec1==60)
{ min1++;
sec1=0;
Posted: Tue Feb 20, 2007 11:58 am |
| In the CCS compiler an int is 8 bits by default. You try to add it up to 1000, this doesn't fit. Change it to int16. |
whung.john Guest
| modified finish pls recheck have any error |
Posted: Tue Feb 20, 2007 8:48 pm |
| ckielstra wrote: | | In the CCS compiler an int is 8 bits by default. You try to add it up to 1000, this doesn't fit. Change it to int16. |
thk u very much.the counter ready is variant units is int16.
i modified follow as .please help me check my modified what have error
#include <16F877.h>
#include <LCD>
int16 j=0;
int sec1=0,min1=0;
#int_TIMER0
set_timer0(100);
if (j++==1000)
sec1++;
j=0;
BYTE i;
DELAY_MS(100);
//unsigned int i;
init74164();
lcd_init();
write_74164(0xf7);
lcd_gotoxy(1,2);printf(lcd_putc,"\fnow sec:=%4u",sec1);
if (sec1==60)
{ min1++;
sec1=0;
Posted: Thu Feb 22, 2007 11:02 am |
| Quote: | | please help me check my modified what have error | What is the error you have now?
Did the previous change improve things? How fast is the clock counting? |
whung.john Guest
| no opinion |
Posted: Fri Feb 23, 2007 9:53 am |
| ckielstra wrote: | | Quote: | | please help me check my modified what have error | What is the error you have now?
my affable friend.
i only hope get suggest,and i can improve more complete for apprentice(me).
so i hope get u sound again (suggest for program). and written
"please help me check my modified what have error " describe.
SORRY,NOT OTHER MATTERS.yet thanks u very much . |
